Old 09-10-2012, 10:17 AM   #1
Wiring diagram for switch please
I have an upstairs hall light and my handy man is not sure how to wire with 2 switches on switch would be downstairs and one upstarts, how would you wire it so the light could be turned on and off from either switch ? We have clear access to both switch box areas and the light wiring area and so we can run any wires anywhere we need
thanks!
petros151 is offline   Reply With Quote
Old 09-10-2012, 10:20 AM   #2
Google three way switch wiring pictures.
Old 09-10-2012, 10:27 AM   #3
Missouri Bound's Avatar
Do you want it your way or the right way?
Is it normal to have the furnace control panel wiring, not match the wiring diagram cjbeck71081 HVAC 6 07-18-2012 12:19 PM
Day & Night furnace wiring diagram Paul Dahlin HVAC 9 03-03-2011 10:08 PM
Sprinkler control wiring re-connect (diagram) ScottR Plumbing 4 06-25-2009 09:51 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 09:59 AM
