Wiring Diagram / Switch Leg Drop - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 01:44 PM   #1
Wiring diagram / switch leg drop
Power to fan/ fan switch, splice to light/light switch, splice to gfci
Is this correct?
toobhed is offline   Reply With Quote
Old 08-21-2011, 02:11 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
Electrically your connections are fine. Where are the connections being made? In the fan & fixture box or a separate junction box?
Make sure the size of the box (in cubic inches) is large enough for the number of conductors and devices.
Coastal South Carolina
Old 08-21-2011, 02:26 PM   #3
Thanks for the reply
I don't have the fan in hand and the install document does not specify the volume, if it is sufficient I will use it, if not I will put the splices in a separate accessible junction box. The light is going in a plastic junction box, 20.5 cu in. No shower in the bath.
Old 08-21-2011, 03:12 PM   #4
A "Handy Husband"
rjniles's Avatar
If you brought the supply to the switch boxes, it only require 1 cable to the fixture and fan.
It would also meet the 2011 NEC that requires a neutral at all switch boxes. Handy down the road if you wanted to install a timer on your fan.
Help Deciphering Wiring (with Diagram) RileyRR Electrical 12 05-23-2011 02:34 PM
Figuring Out Panamanian Switch Wiring machodelmonte Electrical 5 05-16-2011 07:33 AM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 08:14 AM
Wiring Motion Sensor Electronic Lighting Switch consultant Electrical 2 03-07-2010 07:19 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
