Originally Posted by Ggkjk
The sub-panel I purchased is a Homeline 100amp main lug load center part#HOM6-12L100 and I purchased the separate ground bus bar
The 6-12 means you will have 6 full size 1 inch breaker or 12 " twinner breakers "
So let me post them so you will know what it look like.,
A common single pole of HOMline series
Common 2 pole HOMline series,
Now the twinner or tandem breakers of HOMline series.
This is a quad breaker verison of HOMline series and be aware there are few differnt amparage rating and combations it can be used on quad format so make sure you double check what you need it before you get the quad breaker.
Hope that help ya on that one.
Merci,
Marc
