-   -   Wiring diagram for sub-panel (http://www.diychatroom.com/f18/wiring-diagram-sub-panel-165131/)
Ggkjk 11-29-2012 10:29 PM
I'm adding a 100amp (homeline) main lug load center in my attached garage. My 200 amp service entrance is full. I will power it with a 2-pole 60amp circuit breaker. The sub-panel is for the additional gfci's in the bath remodel. Need help with 4-conductor wiring as it enters the sub-panel where they attach?
rjniles 11-30-2012 04:31 AM
Specify the Homeline panel # and we can be more specific. The thing you need to remember is that the neutral and ground must be terminated and kept separate in sub panel. The neutral cannot be bonded to the ground or the metal enclosure of the sub panel. Many smaller panels do not have a separate ground bar and it must be purchased and added separately.
Stubbie 11-30-2012 09:44 AM
1 Attachment(s)
Here is a guideline drawing ask any questions necessary using it as your reference. As rjniles pointed out the sub-panel you purchased would help as separation of neutral and ground is a different process from panel to panel.
Ggkjk 12-01-2012 08:50 PM
Sub-panel brand
The sub-panel I purchased is a Homeline 100amp main lug load center part#HOM6-12L100 and I purchased the separate ground bus bar
frenchelectrican 12-01-2012 09:04 PM
The 6-12 means you will have 6 full size 1 inch breaker or 12 " twinner breakers "
So let me post them so you will know what it look like.,
A common single pole of HOMline series
http://ecx.images-amazon.com/images/...500_AA300_.jpg
Common 2 pole HOMline series,
http://ecatalog.squared.com/pubs/Cir...EAKER_lres.jpg
Now the twinner or tandem breakers of HOMline series.
http://www.foxelectricsupply.com/Con...ct/hom2020.jpg
This is a quad breaker verison of HOMline series and be aware there are few differnt amparage rating and combations it can be used on quad format so make sure you double check what you need it before you get the quad breaker.
http://images.lowes.com/product/conv...69072239lg.jpg
Hope that help ya on that one.
Merci,
Marc
Ggkjk 12-01-2012 11:17 PM
Diagram
I am hoping to get a wiring diagram of the 'homeline' brand 100amp main lug load center sub panel that I will use in the attached garage!
oleguy74 12-01-2012 11:36 PM
there should be a diagram inside the sub-panel.correction for marc...6-12 means 6 single pole or 6 tandems.12 ckts max.
