Wiring Diagram For Lights With Two Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2008, 05:34 PM   #1
Wiring diagram for lights with two switches
My s-i-law is putting two new basement lights on two new (two-way) switches; one switch at the head of the stairs, and one at the base of the stairs.
I need a diagram of how the wiring should be run, and how to hook it up. The power source (control box) is in the basement.
Thank you,
Ed M
Ed M is offline   Reply With Quote
Old 08-09-2008, 05:42 PM   #2
Electrician
simple, run a three conductor cable from switch to switch, line an load come out of switch in basement... clear as mud?
chris75 is offline   Reply With Quote
Old 08-09-2008, 06:04 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
This is that clear MUD Chris is tallking about..... But I think you would be happier with 3-way switches....as shown. If this isn't what you want post back.
Old 08-09-2008, 06:07 PM   #4
Electrician
I wasnt going to hold out for long... just teasing thats all.
Heres a diagram with the feed at the light location.. just come out of the light again to feed the light at the top of the stairs...
Old 08-09-2008, 07:42 PM   #5
Thanks for the help guys. And the switches are 3-way switches. My bad!
Old 08-10-2008, 03:03 AM   #6
Power Gen/RS Engineer
Rewards Points: 566
B-minus. You didn't show the switch poles, Chris (I beat Yoysia on this one!)! What about the note to tape the white wire that is being used as the ungrounded conductor? Tsk, tsk, tsk!
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 08-10-2008, 06:03 AM   #7
Thanks for the information, and also for the links! I appreciate it.
Ed M
Old 08-10-2008, 09:59 AM   #8
Electrician
I know, I was kind of in a rush, have to fix that one up a little...
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
wiring diagram question screenporch21 Electrical 10 11-30-2008 09:14 PM
Does this wiring diagram work? beezlebub03 Electrical 7 05-05-2008 12:54 AM
