I'm installing some lights outside of my garage. I was hoping someone could help me verify this is the best way to wire with what I intend to do.
Two switches part of 4-gang box in garage. Running to junction box in center of one Wall. From that junction box, switch 1 controls two lights. Power also proceeds from the junction box to another junction box (on right in picture) In this box I will splice to UF-B cable to outside light which is controlled by switch 2.
I have some extra 12/3 laying around and I am hoping to use less 12/2 because I also need it elsewhere. I figured could save some some wiring and run 12/3 to the center junction box. Also, the reason I'm not making any splices in light boxes is because I'm using Siding blocks with build-in electrical boxes and fill capacity is only 6.7cu.
Thanks for any help or suggestions.
