Wiring Diagram Help - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2007, 11:40 AM   #1
Wiring Diagram Help
I have an old house and I replaced an old outlet with a new outlet and now only the left side of the outlet works the right side doesn't, when i plug a radio in (the right side outlet) it does not work. I have only two wires and I though I screwed them into the right terminals. and advice on the right wiring diagram?
Designman20 is offline   Reply With Quote
Old 10-22-2007, 12:22 PM   #2
Rewards Points: 82
This is a receptacle? Left side?
If its a standard 120 volt convenience recept, check and make sure the jumper (hot side) has not been twisted off. It may have been a return you ended up with.
Old 10-22-2007, 01:14 PM   #3
yes it's a receptacle, the left side works when i plug a light in but the right side outlet does not....since i know little about the jargon of the electrical world....when you say" JUMP" what does that mean? i have 2 silver terminals on the top and two brass terminals on the bottom and i have two black wires coming out of the wall. how do i wire this outlet?
Old 10-22-2007, 06:46 PM   #4
joed's Avatar
Rewards Points: 12,026
Look between the two screws on each side of the receptacle. There should be a metal tab connecting those two screws together. If it is broken off on either side the receptacle will only work on one of the positions.
Need Luxaire Forced Air Furnace Wiring Diagram misticvillage HVAC 7 04-15-2009 05:09 AM
wiring diagram question screenporch21 Electrical 10 11-30-2008 09:14 PM
wiring diagram potter67 Electrical 42 09-19-2007 01:30 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
