10-01-2012, 11:31 PM
#1
Wiring diagram for dummies please
Hello all,
Can someone sketch me a simplified drawing on how to run #12 wires from a 120 V lighting panel, 20 amp spare breaker to 4-85 watt induction lights.
Do I need a H, N and Ground? Or can I use a black and white?
When I get to first light, where do I terminate and where do I land my black and white wires on the next 3 lights?
I would appreciate any help on this matter....just assume that the lights will stay on all the time. There is an existing photocell that will be used but worried about making lights work....
Thank you!
10-01-2012, 11:40 PM
#2
Semi-Pro Electro-Geek
Where are you located, what kind of building is this in, and what do you mean by "induction lights"? The only context I know for the term "induction lamp" is to refer to electrodeless gas discharge lighting like microwave-excited sulfur lamps, which are mostly experimental. I hope that's not what you mean.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
10-02-2012, 12:04 AM
#3
Originally Posted by notredave
Hello all,
Thank you!
How can we tell you how to run wires from point A to point B? All we can advise is that you will need a ground of some sort, either with the wire or conduit if you are using it.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-02-2012, 12:14 AM
#4
Can you post pic's of the breaker panel,
and the lights terminals,
so we can see more details ?
Too general a question.
10-02-2012, 09:15 AM
#5
This is at a chemical plant. I am going to draw a sketch for an E/I contractor to route 3/4" conduit from lighting panel "a" to the 4 Appleton, 85 watt induction lights. I just need to know how many wires to draw. Start at the spare 20 amp breaker to first light. Then I want to parallel the reamining 3 lights....can someone draw something up for me please?
thank you
10-02-2012, 09:18 AM
#6
ground wires not shown for ease of drawing
The Following User Says Thank You to hammerlane For This Useful Post:
10-02-2012, 09:21 AM
#7
custom user
A chemical plant wants a total novice to draw up electrical plans? Do they manufacture bovine excrement there?
The Following 2 Users Say Thank You to JasperST For This Useful Post:
10-02-2012, 09:33 AM
#8
Experienced
I guess induction lighting is the answer to hard to service areas
http://www.lithonia.com/micro_webs/i.../induction.asp
Mark
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-02-2012, 09:35 AM
#9
Thank you hammerlane for the sketch and not being a smartass like others....I appretiate it
The Following User Says Thank You to notredave For This Useful Post:
10-02-2012, 09:47 AM
#10
Electrical Contractor
Hopefully you are hiring a compentent contractor that would not need such a simple drawing.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
10-02-2012, 09:48 AM
#11
Licensed electrician
I would hope your contractor would know how to route conduit and the number of wires needed.
10-02-2012, 09:49 AM
#12
custom user
Well, you can consider it smartass but if it was me given the responsibility to perform the task I would learn how to do it instead of asking someone on the internet to do it for me. I'm just not believing that a chemical plant would be in that position.
10-02-2012, 10:08 AM
#13
Experienced
I always thought that the simple minded (dummies) were not so easily insulted......guess I was wrong, learn something new every day.
The Following User Says Thank You to Jackofall1 For This Useful Post:
10-02-2012, 11:00 AM
#14
Average Joe/ex-Navy IC3
I other words, grow op or drug lab.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
10-02-2012, 12:31 PM
#15
thank you
You contractor doesn't need a sketch for that. Just show the fixture locations, switch location, and panel location. The contractor will route everything. That's their job. And you don't need to draw the individual conductors, a one-line diagram is standard.
Just exactly what kind of, uh, "chemicals" does this "plant" produce, anyway?
The Following User Says Thank You to mpoulton For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
