Old 01-21-2012, 01:58 PM   #1
Wiring Diagram for ATT NID box needed
My German shepherd pulled the wires from the AT&T NID box this morning. Rather than wait until Monday, I think I can fix this myself. Only problem is wire coring is not matching up. Two twisted pair wires coming from AT&T, blue an orange need to be connected into the NID box. It would be great to see how a current AT&T Uverse box is wired from someone else. I am posting a couple of pics if anyone has suggestions. Thanks.
Wiring Diagram for ATT NID box needed-image-1874414711.jpg   Wiring Diagram for ATT NID box needed-image-2447700882.jpg
cm6848 is offline   Reply With Quote
Old 01-21-2012, 02:12 PM   #2
Licensed electrician
The blue/blue-white should be pair one, with orange/orange-white as pair two.
How many numbers do you have coming into the house?
Old 01-21-2012, 02:24 PM   #3
We have Uverse with cable, Internet, and VOIP services! Don't know if that helps.
Old 01-21-2012, 03:45 PM   #4
Just one phone number but 4 data streams is a term they used also!
Old 01-21-2012, 06:59 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
Blue/Blue-White from the pole to my NID, Green/Green-White from the NID to the RJ-11 Keystone inside. Try that. You can also pull the cover off of the keystone jack inside and make sure that it is green/green-white, other wise blue/blue-white. I have U-verse so if you have any other questions regarding.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Wiring Diagram for a Transformer XR72 Electrical 7 08-12-2009 09:20 PM
Need Luxaire Forced Air Furnace Wiring Diagram misticvillage HVAC 7 04-15-2009 05:09 AM
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 33 03-18-2009 08:11 PM
Celiera 18000 Split AC/Heatpump, power wiring diagram? trinhyulinh HVAC 2 08-03-2008 01:36 PM
wiring help needed.... ryanVT Electrical 14 12-17-2007 10:40 AM
