Old 03-17-2011, 01:02 PM   #1
WIring Detached Garage
I am wiring a detached garage with a 100 amp subpanel off my main 200 amp panel, I am running from the main panel 4 - 3 gauge wires. One is green insulated for ground and the other 3 are black identified as white, red and black. My plan was to run all 4 wires in 1 1/2 conduit from main panel to sub panel. I assume the ground I run from the main to the sub panel is sufficient grounding. My question is do I still need to ground the sub panel to a ground rod at the garage? If so do I just ground the can or do I ground to the grounding bar in the panel? I don't think I can sink it 8 feet because of rock. Is this an issue?
I will have a 100 amp breaker in my main panel to support the subpanel.
Thanks in advance
btedford is offline   Reply With Quote
Old 03-17-2011, 01:08 PM   #2
I=E/R
a7ecorsair's Avatar
You will need a ground rod. You will also have to make sure the neutral bar and ground bar are separate and that there isn't a bonding screw installed in the neutral bar. The ground bar will need to be bonded to the panel case or directly mounted on the case. Check with your inspector and see if he will allow the ground rod to be laid in the trench or driven at an angle.
a7ecorsair is offline   Reply With Quote
Old 03-19-2011, 06:50 AM   #3
Thanks for the answer. If I sink a ground rod at the garage do I still need to run a ground wire from the 200 amp panel to the 100 amp panel or is the grouding rod sufficeint?
This work is being done in Newfoundland.
Old 03-19-2011, 09:02 AM   #4
Just call me Andrew
You only need a #8 ground wire for 100 amp:
Andrew
secutanudu is offline   Reply With Quote
Old 03-19-2011, 12:40 PM   #5
J. V.'s Avatar
Thanks in advance
Are you using single wires or a cable? You mention white? Rarely do I see white sold separately at size #3. I am certain its available, but seldom would be used, as #3 can be re-identified.
If you have a cable, post what type of cable you have.
Old 03-19-2011, 02:55 PM   #6
I'm using 3 gauge 7 strand black insulated for all colours. I already have the ground wire in 3 gauge green insulation.
If I ground to a separate ground rod at the garage do I still need to run a ground from the mainpanel to the subpanel in the garage?
Old 03-19-2011, 04:27 PM   #7
Just call me Andrew
What is the marking on the actual wire? Is it copper?
Andrew
Old 03-20-2011, 07:07 AM   #8
The wire is 7 strand copper.
Old 03-20-2011, 08:46 AM   #9
Just call me Andrew
Tha'ts not enough information, what does it say on the wire? THHN? THWN?
Andrew
Old 03-20-2011, 09:09 AM   #10
#4 or larger wires may be remarked as neutral or ground.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Painting Detached Garage Exterior bsmith95610 Painting 3 02-15-2011 07:52 PM
Wiring Detached Garage for 220v welder 8N1949 Electrical 2 03-11-2010 09:47 AM
wiring detached garage dave d Electrical 1 01-11-2009 10:00 AM
detached garage Kapt Electrical 12 01-17-2007 09:37 AM
