Wiring A Dedicated Switch To A Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2008, 05:08 PM   #1
Question
wiring a dedicated switch to a outlet
I have an older home circa 1960 calif. I'm trying to wire a dedicated switch for a garbage disposal plugged into an outlet beneath the sink. at the switch I have 2 blk and 2 white wires with no groung. Both blk wires are connected to the switch on either side of a new switch. the white wires ane conected and capped off. Below the sink the outlet is new and has a ground. Blk conected on rt side. white conected on left . ground wire to ground screw. With switch on I get 118vlt from blk wire at outlet when grounded to ground. I get a reading of 2.5 to 4.1 vlts going from bk to white and the outlet. Any sugestions? Michel
Michel is offline   Reply With Quote
Old 09-18-2008, 05:12 PM   #2
joed's Avatar
Rewards Points: 12,918
The wire needs to go from the switch to the receptacle. How can you have a ground at the receptacle and not at the switch?
Your readings are indicating that the white wire is open.
Old 09-18-2008, 06:25 PM   #3
BX?
The white wire is the return path (to the panel) for the voltage.
Re check your white to white connection at the sw box. The circuit may go thru several more recepticals/switch boxes befote it finally ends at the panel. Check the connection at the panel too.
220/221 is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
help with wiring ceiling fan from a switch controlled outlet teamster807 Electrical 39 10-27-2011 04:09 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
