Wiring Dayton 2ryn7 Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 02:53 AM   #1
I have a Dayton belt sander. Model number 2ryn7...
I am trying to wire it to 120vac
I have the following wires from the motor with the following numbers on them:
1 - Black
2 - Grey
3 - Red
4 - Yellow
Blue (no number)
There is a capacitor with two wires...
Then obviously I have the incoming hot/neutral/ground wires...
Could someone please help me with the wiring to make this spin the normal direction. Thanks so much!
jeronthenet23 is offline   Reply With Quote
Old 05-20-2013, 07:49 AM   #2
Rewards Points: 3,130
"Trying to wire it to 120vac?" What voltage does it run on now?
Dayton is a W.W. Grainger house brand. Maybe you could try calling their customer service department.
Old 05-20-2013, 11:44 AM   #3
Rewards Points: 80
Graingers web site says it 120/240. http://www.grainger.com/Grainger/wwg...rue&sst=subset
OP. Look at the motor nameplate either on the outside or maybe on the inside of the connection box cover for the low voltage connection wiring diagram.
J. V. is online now   Reply With Quote
Old 05-20-2013, 12:03 PM   #4
It was wired to 120 but was taken apart. Also there is no diagram on the motor anywhere. Now I can't seem to get the right wire combo to get it to spin...
Old 05-20-2013, 08:46 PM   #5
Idiot Emeritus
Rewards Points: 1,492
I'm kinda guessing here, as the colors don't match the industry standard numbers, but here goes;
I suspect this motor is 115/230 and not reversible.
If so, the incoming hot goes to 1 (Black).
The incoming neutral goes to both 2 (Gray) and 4 (Yellow).
Blue splices to 3 (Red).
The above is for 115 volts.
Rob
micromind is offline   Reply With Quote
Old 05-20-2013, 08:50 PM   #6
Rob
I got all of that. Could you detail a little more on how the capacitor wires into the motor. It has two wires coming from it...
Old 05-20-2013, 08:59 PM   #7
Idiot Emeritus
If the capacitor is not connected inside the motor, don't hook it up the way I described.
I need to know if the motor is thermally protected or not. This makes a difference where the blue wire goes.
Rob
Old 05-20-2013, 09:35 PM   #8
Rob
How would I figure that out?
Old 05-21-2013, 12:30 AM   #9
Idiot Emeritus
Look on the nameplate. If it states 'thermally protected', then it is. If there's nothing, then most likely it's not. It might also state 'thermally protected', and have a box that states 'not' next to it.
If it's not protected, and the capacitor is mounted in the terminal box and its two leads are not connected to anything, try this connection.
Note, this is not an absolute correct answer, it's based on my knowledge and experience with motors, nothing else.
Connect the blue lead to one of the capacitor leads. It doesn't matter which one.
Connect the incoming hot wire to both 1 and 3.
Connect the incoming neutral wire to 2, 4, and the other capacitor lead.
If it just hums and doesn't turn, remove the capacitor lead from 2 and 4, and connect it to 1 and 3.
wiring franklin inst-o-verse motor bernie963 Electrical 14 04-30-2013 10:38 AM
Ceiling Fan Motor WIRING tamflrx Electrical 1 04-17-2013 06:50 AM
Help with motor ID and wiring pk1 Electrical 46 02-09-2012 11:04 PM
Blower Motor Wiring reversed? HVACMac HVAC 60 08-30-2011 03:10 PM
Wiring a Dayton 4m261G wrangler HVAC 11 10-10-2009 12:33 PM
