Wiring On Cylinder Block Walls - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 10:14 PM   #16
Ahhhh..I see.
I don't connect the NM to the EMT.
220/221 is offline   Reply With Quote
Old 11-14-2008, 12:32 AM   #17
Registered User
Termite's Avatar
I might be missing something, but I'm with 220/221 in that I don't see a reason to connect the NM wire to the EMT. Are we talking about a romex clamp-type connector at the end of a run of conduit? There probably is one, but I can't think of any circumstance that would necessitate using that fitting.
Old 11-14-2008, 02:42 AM   #18
DIYer
Yes we are, and there is indeed one. It only seems to exist in 1/2 inch though. That is why I'm concerned, it's much easier to put 2x12/2 romex down 3/4 inch than 1/2 inch. People might think they are limited to 1/2 inch.
It was recommended earlier in this thread even:
Originally Posted by rgsgww
Use conduit with the proper fittings, you should use emt and emt to romex connectors
220/221 said this and I thought he was referring to the same thing:
Originally Posted by 220/221
I would use EMT connectors at the top of the conduit
But apparently he was referring to a normal device connector, with the threads just hanging.
Gigs is offline   Reply With Quote
Old 11-14-2008, 02:50 AM   #19
" Euro " electrician
frenchelectrican's Avatar
Let me add addtional comment related to this.
In unfinshed basement you will require a GFCI protection on receptales in unfinshed basement.
Keep in your mind when it become finshed basement room it either will stay on GFCI or switchover to AFCI depending on the code cycle and what the local requirement will be add to it.
Merci,Marc
Old 11-14-2008, 02:59 AM   #20
DIYer
http://www.acehardwareoutlet.com/(fd...px?SKU=3002912
That reminds me, I'm going to have to order these. They don't have them at my local store, and I'm not paying the price for a GFCI breaker!
Old 11-14-2008, 08:43 AM   #21
joed's Avatar
Rewards Points: 11,598
Wiring on cylinder block walls
Why is he trying to put wiring on his car engine or is his basement built out of old engine blocks?
A cylinder block
Old 11-14-2008, 12:23 PM   #22
Rewards Points: 58
Originally Posted by InPhase277 View Post
Try the "zamac" hammer drive pins. I used to swear bu tapcons, but I have had them loosen on me. A zamac won't come out. I won't fasten anything to concrete or block with anything else.
I use the "nail ins too". They will come out with a heavy hammer and chisel. Of course any device (box/strap) will be destroyed by removing them.
I like the option to remove the screw if needed. I was raised on nail drivers and like them as well.
Old 11-14-2008, 12:42 PM   #23
Rewards Points: 2,350
If you get the hammer-drives from a home center, like Home Depot, they don't have the option to remove the center pin. The ones I buy from the electrical supply have a phillips head on the center pin, so
they can be backed out. Then a gentle tap will loosen the body, and you remove it with piers.
Old 11-14-2008, 04:11 PM   #24
DIYer
A cylinder block
It took me quite a while to figure out he meant "cinder block" too. I thought there was some kind of strange building material I hadn't heard of.
Old 11-14-2008, 05:48 PM   #25
Correct......except it's a box connector. A device would be a sw or recep. The insulated throat protects the cable from the raw edge of the conduit.
I didn't even notice the cylinder thing
Old 11-14-2008, 05:53 PM   #26
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Nice picture Joe.... I think metal fasteners and a ramset would be compliant. So long as you didn't install the pistons.
Old 11-15-2008, 02:36 PM   #27
joed's Avatar
I figured that was what he meant but couldn't resit the urge to post the picture.
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
Locate wiring in walls fw2007 Electrical 4 10-02-2007 10:23 AM
Required support for wiring in walls? leonsphinx Electrical 5 02-23-2007 07:25 AM
block walls orenawilliam Building & Construction 2 02-15-2007 01:00 PM
