Old 11-12-2008, 01:43 PM   #1
jelly's Avatar
Wiring on cylinder block walls
Friend of mine wants to install outlets, switches and lighting in his unfinished basement. He will not be finishing the walls so the wiring will be installed directly on the cylinder block walls.
What do i need to do differently than wiring on studs? I assume I need to run conduit of some sort. Are there any general codes that I need to consider?
jelly is offline   Reply With Quote
Old 11-12-2008, 02:01 PM   #2
jamiedolan's Avatar
Yes, there are codes to consider. I don't know what you mean about wiring on studs?
You need to use ridgid conduit on the exposed walls, the common choice is called EMT, in 1/2 inch, it is metal conduit that is used for electrical work.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-12-2008, 02:45 PM   #3
jelly's Avatar
Thanks Jamie, I just meant typical wiring on wood studs. Thanks for the tips.
Old 11-12-2008, 02:58 PM   #4
Building codes guy, Mod
thekctermite's Avatar
Agreed, you have to use conduit to protect the wires from physical damage wherever they drop down against the cinder blocks from the ceiling or up from the floor. Horizontal runs need to be protected as well. EMT is a great option, and is reasonably DIYer friendly.
thekctermite is offline   Reply With Quote
Old 11-12-2008, 05:50 PM   #5
Always Learning
Use conduit with the proper fittings, you should use emt and emt to romex connectors. Make sure the boxes are bonded to the ground conductor.
A lot of people forget about the bushings or fill capacity. Make sure your not overfilling the conduit. Do not strip all of the sheathing off of the romex when in the conduit.
rgsgww
I think I'm addicted to this site...
rgsgww is offline   Reply With Quote
Old 11-12-2008, 06:18 PM   #6
I would use EMT connectors at the top of the conduit to protect the cable from the raw steel edge. Staple the cable cleanly after it exits the conduit.
I would use 4 square deep boxes and industrial device covers.
I would use 1/4" plastic screw anchors and minimum 1 1/4" long #10 screws
I would use 3/4" conduit with two straps on the block.
Ground/bond the metal boxes.
220/221 is offline   Reply With Quote
Old 11-13-2008, 12:55 PM   #7
Licensed Electrician
J. V.'s Avatar
Ever since I have used concrete screws I will never go back to anchors of any kind except "nail ins" . I love the blue screws. A little pricey but well worth the time saved. I think they make a drill bit/driver in one piece so you do not have to change from drill bits to drivers.
Old 11-13-2008, 03:37 PM   #8
My License Ain't 4 Sale..
Try the "zamac" hammer drive pins. I used to swear bu tapcons, but I have had them loosen on me. A zamac won't come out. I won't fasten anything to concrete or block with anything else.
Old 11-13-2008, 04:45 PM   #9
jamiedolan's Avatar
Those are what I use to attach outlets and switch boxes to my basement walls.
Line them up stright the first time, as unlike tapcons which are fairly easy to remove with a screw gun and nut driver, as Inphase said, they don't come out, even if you want them to.
-Jamie
Old 11-13-2008, 08:04 PM   #10
I refuse to use these because
I do a LOT of retro work and I like things to come apart
Somebody, someday is going to have to remove it.
Old 11-13-2008, 09:06 PM   #11
Electrician
I know what I would do, nail some 2x's flat to the wall and run the NM down that. Emt is going to cost more in material and labor. Although, most areas are not as smart as the Northeast, so your area may not allow exposed NM period. *dumb in my opinion*
chris75 is offline   Reply With Quote
Old 11-13-2008, 09:17 PM   #12
DIYer
I'm pretty sure fill capacity does not apply. Otherwise I don't think 12/2 romex would not be allowed at all in 1/2 inch EMT, since I believe you have to consider it as if it were round and the diameter of its biggest cross section.
Gigs is offline   Reply With Quote
Old 11-13-2008, 09:18 PM   #13
DIYer
You all are recommending these a lot lately for sleeving romex. As far as I can tell, they only come in 1/2 inch. You all ever jam two 12/2 romex down 5 feet of 1/2 inch EMT? It's no fun. I am using 3/4th inch now and it's way nicer.
I went with those plastic bushings instead, because they come in 3/4th inch (and all sizes). The 2005 code mentions a "nonmetallic bushing" as being acceptable, though in 2008 they strike the word nonmetallic, presumably to clarify that the EMT to NM metallic fittings are permitted as well.
Old 11-13-2008, 10:03 PM   #14
Electrical Metalic Tubing is 1/2" thru 4".
Old 11-13-2008, 10:04 PM   #15
DIYer
I did a lot of searching and the EMT-to-NM fittings only come in 1/2 inch that I could find.
The plastic insulating bushings however, come in every trade size.
More On This Topic
Moving Electrical Boxes
Moving Electrical Boxes by Expert Village
Were in the process of pulling out the old electrical boxes and were going to move them to the new wall. I have removed this one and here?s the wire hanging here I did shut the power off before I got started in this and they are all these wires are... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be answering the question, what does a laser line level stud finder tool do? The tool that we're going to focus is primarily on in this segment of video clips is a combination stud... Read More »
If you want to install an outdoor fan, you should wire a nearby switch so you can control it easily. There are various types of switches that you can use, but what matters most is that you are using components that are safe for outdoor use. Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we will be detecting live wires. On our stud finder tool we have this real handy feature that will tell us if there's a live wire behind the wall that we're moving this tool across. Now this... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be talking about tips for buying a stud finder. I have two different types of stud finder tools and each one has its own pros and cons. On our first tool our stud finder gives us the... Read More »
Keeping Water out of the Top of Brick Walls o2barockstar Roofing 4 02-18-2008 03:50 PM
Locate wiring in walls fw2007 Electrical 4 10-02-2007 10:23 AM
Required support for wiring in walls? leonsphinx Electrical 5 02-23-2007 07:25 AM
block walls orenawilliam Building & Construction 2 02-15-2007 01:00 PM
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 3 05-15-2006 01:53 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
