Wiring - Crawl Space Or Attic? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2012, 10:55 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
Wiring - Crawl Space or Attic?
Just curious....preference?
I have it both ways. Gettting ready to do a lot more....
I like the attic because it's easier to access and work on.....but it's not as easy to get it down the wall...(smoke blocks)
Crawl space...typically shorter runs...easier to to an outlet....drill a hole in the bottom plate...have wife grab the wire when I stick up up near the hole for the box...
Old 05-05-2012, 11:14 PM   #2
kevinp22's Avatar
Rewards Points: 252
my attic is unfinished and a pain to use, so i prefer crawl space.
100 degree temps in attic mean i didnt work up there from may to sept
my crawl is dry and easy to access, i can see hoe others would not want to use it if it is a pain to get into
kevinp22 is offline   Reply With Quote
Old 05-06-2012, 06:42 AM   #3
Code05's Avatar
Rewards Points: 1,104
I believe that CA moved to the 2008 not that long ago.
FYI, 334.15(C) has changed. Crawl spaces was added.
(C) In Unfinished Basements and Crawl Spaces. Where
cable is run at angles with joists in unfinished basements
and crawl spaces, it shall be permissible to secure cables
not smaller than two 6 AWG or three 8 AWG conductors
directly to the lower edges of the joists. Smaller cables
shall be run either through bored holes in joists or on running
boards....................
Code05 is offline   Reply With Quote
Odor from Crawl Space G Ollis General DIY Discussions 68 11-02-2013 01:31 AM
Crawl Space Issues / Too Many Layers of Floor jdmindy71 Flooring 1 12-31-2010 05:09 PM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 11:36 AM
crawl space and moisture Jeremy Hillary Boob, PhD Building & Construction 5 11-27-2008 08:13 PM
rats is my crawl space and in my attic this old house Pest Control 5 06-02-2007 05:48 PM
