Wiring A Counter Top Stove - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2008, 09:21 AM   #1
Question
Wiring a counter top stove
We are replacing a free standing stove/oven with a built in oven and counter top stove. Can I wire both new appliances through the one existing 220 wire? If so, where can I get a diagram?
Johnny Reb is offline   Reply With Quote
Old 09-04-2008, 11:19 AM   #2
Rewards Points: 58
What is the current rating for each appliance? And what size breaker do you have. I am not sure, but I think you need a dedicated circuit for each appliance. Someone will clarify.
Old 09-04-2008, 12:36 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes may do this for any cooking branch circuit rated not more than 50 amps. In most cases free standing ranges are 40 or 50 amps. So you should have one or the other existing. The conductors to the oven and stove top are considered tap conductors whether factory or field installed and must be at least 20 amp rated and must be sufficient for the load served. They must be ran to a junction box (one jb not two) adjacent to both pieces of cooking equipment where they will splice to the branch circuit from the panel.
You also probably have a neutral wire in the existing range circuit this may or may not be needed.
Old 09-04-2008, 12:44 PM   #4
Thanks Stubbie. I will verify the amps and go from there. The wiring for the original free standing stove/oven comes through a junction box and so I splice it all there, right?
Old 09-04-2008, 12:49 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
This image from Mike Holt gives the general idea.....only you have one oven
Old 09-04-2008, 02:11 PM   #6
Perfect, thanks Stubbie...
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 12:53 PM
Wiring stove outlet in old house electric-pete Electrical 23 07-06-2008 04:02 PM
Stove top wiring teh3515 Electrical 2 04-03-2008 04:47 PM
New stove wiring black,red,white where. 2pyrs Electrical 2 12-18-2005 12:13 PM
Stove wiring? OSt8Pokes Electrical 2 03-01-2005 06:53 AM
