Wiring Cooktop And Under Counter Oven - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-19-2009, 09:46 AM   #16
Wiring Cooktop and Under Counter Oven
Thanks for the response, I will use two separate boxes but can anyone tell me why I was told here to connect the oven/broiler to the #8 wire when its maximum load is only 5000 watts (3000 Broiler and 2000 Oven) when the cooktop draws higher at 6600 watts?
Preach_2 is offline   Reply With Quote
Old 03-19-2009, 10:01 AM   #17
Rewards Points: 2,350
Because he didn't pay attention to which one was the higher wattage. Wire them appropriately for the power requirement.
Old 03-19-2009, 10:14 AM   #18
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I'm not sure why that advice was given, considering the load requirements. You likely will never broil and run the oven similtaneously as you generally (to my knowledge) have to select one or the other. So 3000 watts would be your actual max. on the oven/ broiler.
Follow the cooking units instructions as for the circuits they require, two separate branch circuits to each unit would be better but I don't see any reason to not use the exception for both on a 40 amp branch circuit either. If you were broiling on the max setting you would still have 6600 watts available for the cooktop using the 40 amp single circuit with #10 taps to the oven/broiler.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-19-2009, 04:30 PM   #19
I'm not sure why you say connect the #8 wire to the oven instead of the cooktop.
A) Out of hundreds, I have never seen a cooktop that required more than a 30 amp circuit.
B) A future double oven or oven/microwave will require a 40 or 50 amp circuit.
That's my logic.
220/221 is offline   Reply With Quote
Tags
240 amp , cooktop , oven , wiring
