Wiring A Contactor - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2009, 01:21 PM   #1
Question
Wiring a Contactor
I am installing a 5hp 220v dust collector. I have a 30amp 220 circuit, a contactor ( see http://www.geirelays.com/acrobat/Con...CContactor.pdf -- NC1-3210 ), and a 220v remote control switch (long ranger 220v).
I get the Lx/Tx for the power, but how do I wire the 220v to the relay ?
There are two connections (13-NO & 14-NO ) . Is that where the "hot" connections go?
Thanks Electricians!
lrr81765 is offline   Reply With Quote
Old 03-10-2009, 02:06 PM   #2
Remodeling Contractor
the two NO (normally open) contacts on the relay are for the 220V hot feed from the switch. When powered they close the contactor connecting the power feed to your machine
Old 03-10-2009, 02:19 PM   #3
Thanks for the quick answer!
Just to clarify, and hopefully for someone who searches later. I attached a pic. The lines in are 220V.
Old 03-10-2009, 04:02 PM   #4
Advice worth 2 cents!
Rewards Points: 150
NO! that diagram is not right! neither is Bob's answer.
First off, Why three wires to a single phase motor?
Second, make sure you know the voltage of the contactors coil, it could be either 220 or 110.
The NO contacts are for the motor not the coil. I'm not sure by looking at the picture but be careful, 13 & 14 could be auxiliary contacts and are not the coil! (if you put 220v on them and close that contactor, it's going to go BANG!)
The coil screws can be tested with and ohm meter (there's going to be continuity).
_pete
---pete
HandyPete is offline   Reply With Quote
Old 03-10-2009, 05:07 PM   #5
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Looking at that contactor, the coil wires are A1 & A2. As stated, right where those wires go, you need to look at the coil voltage.
13 & 14 are just auxiliary contacts on the contactor.
wirenut1110 is offline   Reply With Quote
Old 03-10-2009, 07:58 PM   #6
Wirenut has it right.
A1/A2 (and it is 220v) is the coil for the contactor.
13/14 are aux
And there are two wires to the motor..
Thanks alot guys!
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Contactor Coil Wiring dmend Electrical 2 04-30-2008 10:06 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
