Wiring Confusion, Please Help! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 09:28 AM   #16
Ok, so I went into the wall and found where the multi colored cable was connected. Only three of the colored wires were being used and the other three were just wrapped back around the covered grouping of wires. The colored wires were connected to one black wire coming off the top screw of the switch. I discovered that the other black and white wire were coming to the switch to bring it power i'm assuming since it is the old type of wiring used throughout the house. So now I am going to take out the colored wire completely. What do I need to buy and do now to connect my light back to the black wire which I assume is the hot wire.
davidbisok is offline   Reply With Quote
Old 11-08-2013, 12:53 AM   #17
Rewards Points: 386
you need to know the size of the cable 12-2 or 14-2 if you are going to just turn the light & fan on off at the switch, then if there is power coming into the switch box from the breaker panel. twist the white wires together, add wire nut, then the black from the power would go on one side of the switch then the wire from the fan would go to the other screw. you should be good to go.
circuitman is offline   Reply With Quote
Old 11-08-2013, 06:10 AM   #18
PoleCat's Avatar
Rewards Points: 1,652
Since you have a three way switch in there you need to verify what each wire is doing. White wire may not be acting as a neutral and nutting it to an actually neutral will give you a dead short.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Tags
electric , fixture , light , wiring
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
