Wiring Code In Ontario - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 07:58 PM   #1
Wiring Code in Ontario
Hi,
I am building a new log house. Could someone please tell me what the electrical codes are in Ontario?
enorman is offline   Reply With Quote
Old 06-04-2010, 08:00 PM   #2
Master Electrician
umm that's pretty vague....electrical codes on what?
it would take me a year to type out everything you need to do for a new home.
andrew79 is offline   Reply With Quote
Old 06-04-2010, 08:10 PM   #3
Master Electrician
as for the wiring...get the sparky to coordinate with the carpenters to allieviate some of the crap. Log homes aren't the easiest thing to do. Use window and door frames for wire chases when possible and forget about changing anything once it's wired.
Old 06-04-2010, 09:10 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Would modern log homes still have 2x4 or 2x6 studs inside with drywall? I would imagine so, so it can be insulated. Then it would probably be same codes and techniques as any other house.
Asking for "wiring codes" is quite vague, if you are really not sure I would get someone to maybe give you a quick crash course so you know what you are getting into. For example, what size wire you need for what amperage breaker, the fact that junction boxes can't be hidden, breaker panel clearances and many many more.
Old 06-05-2010, 10:27 AM   #5
joed's Avatar
Rewards Points: 13,752
That's too wide open a question. There are many special rules for kitchen counters, bedrooms(AFCI), laundry room, tamper proof receptacles are now required, GFCI requirements, fridge circuits, light circuits etc.
If you have a specific question ask it.
Where to find an online electrical code for Ontario? Red Squirrel Electrical 14 06-26-2014 06:43 AM
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Apartment wiring up to code?? camden2200 Electrical 1 08-02-2009 11:19 PM
Wiring Problems sunici Electrical 18 04-26-2009 08:27 PM
'Underground Wiring And Code. michaeltz Electrical 16 12-05-2005 07:58 AM
