Wiring A Circuit Plug Controlled By A Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 10:28 PM   #1
wiring a circuit plug controlled by a switch
How do I wire a plug that is controlled by a switch that is in a circuit with 2 other plugs?
shannacat123 is offline   Reply With Quote
Old 05-22-2011, 10:36 PM   #2
Licensed electrician
Rewards Points: 1,038
Is this all new wiring? Do you want all the receptacles to be switched? What is the arrangement of the devices?
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 10:58 AM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
