Wiring For A Cieling Fan And Light Combo - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2011, 02:47 PM   #1
Wiring for a cieling fan and light combo
I have a ceiling fan light combo. I have taken the two of them apart to make one that will work. Inside the box on the up side where all of the wiring for the light and the fan with the pull chains and the switch for the direction of the fan is, is where I am having trouble putting that back together. I make diagrams of each but did not notice the wires are different colors in each of these. I am not sure what wires to hook together. Do you have a diagram of how this should be wired so I do not burn something up?
Verden
Verden60 is offline   Reply With Quote
Old 10-03-2011, 02:51 PM   #2
joed's Avatar
Rewards Points: 13,710
Make and model might make getting the info easier.
Old 10-03-2011, 03:04 PM   #3
Your reply to not use use a PM with questions that can be asked in a forum and that you will not respond. I have no idea what you are talking about when you say PM with a question, what does that mean? What is this forum you talk about?
Verden60
Old 10-03-2011, 04:52 PM   #4
joed's Avatar
That's signature that goes on every post to ask people not to Private Message with questions that should be asked in public forums.
Most fans have a plug to connect the lighting fixture. If you post the make and model of your fan maybe someone who knows the brand can give you and exact answer.
