Wiring A Ceiling Light/fan - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 03:23 PM   #1
wiring a ceiling light/fan
How to install a ceiling fan light when the power 14/2 goes to the fan/light then to the fan/light control (blue, black, black/white, green)?
Rob Wright is offline   Reply With Quote
Old 04-25-2012, 03:25 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Is the box fan rated?
Old 04-25-2012, 04:50 PM   #3
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Are you saying you have a 14/2 romex or some 14 gauge, two conductor cable at the ceiling box? In other words, just two conductors in the ceiling (hot and neutral)?
If you could explain the wires at the ceiling box and the wires at the wall switch, it would help a lot. Also, post the wiring for your fan/light and wall switch.
JulieMor is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 07:48 PM
Wiring A Porch Ceiling Fan TFSpaniel Electrical 14 07-22-2011 11:04 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
