Wiring From Ceiling Help - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 04:18 PM   #1
wiring from ceiling help
Trying to hang a fan with a light. Both will be controlled by the same switch. The problem is, the switch isn't controlling the fan or the light. Coming out of the ceiling are a ground, two black wires and one white wire bundled together, and two white wires bundled together. I connect the blue and black wires from the fan to the 2 black and 1 white bundle from the ceiling and the one white wire from the fan to the two white wire bundle from the ceiling. THe fan operates, but the wall switch has no control over it. Can someone please explain what is going on and how to fix it?
Thanks!
CocoLos is offline   Reply With Quote
Old 06-16-2012, 04:47 PM   #2
Sparky
Rewards Points: 510
Should be a 3rd black by itself (from the same cable as the white with 2 blacks), this is your switched wire.
The receptacle shown could be any unswitched device/box
Techy is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 07:48 PM
Wiring A Porch Ceiling Fan TFSpaniel Electrical 14 07-22-2011 11:04 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
