Old 05-12-2009, 08:20 AM   #1
Question
wiring ceiling fan to light switch
I have a ceiling fan with a light package that I am installing in a room with no light fixture. The light switch in the room controls a wall socket only. Can I wire this from the light switch
cshsr is offline   Reply With Quote
Old 05-12-2009, 12:35 PM   #2
J. V.'s Avatar
Does the switch control more than one receptacle? If it does you will have to sacrifice all but one of them for the fan and light. Switching that is.
The best way to go is to fish a 3 conductor cable from the switch up into the attic and into a fan box. This way you can control the fan and light independently.
I would think it will be easier to fish the cable up through the switch box than it would the receptacle. But I am not the one going fishing, you are. Good luck.
Old 05-12-2009, 12:51 PM   #3
When you say 3 wire you mean one with white , black and red leads? the switch only controls one outlet.
Old 05-12-2009, 12:52 PM   #4
joed's Avatar
If you want to wire the fan into the light switch then you have give up the switching capability of the recpetacle. The receptacle will have to always on.
http://www.selfhelpandmore.com/switc...switched-plug/
Do not PM with questions that can be asked in a forum. I will not respond.
Old 05-12-2009, 12:52 PM   #5
Maybe.
You may have to rewire and sacrifice the half switched recep.
How many wires/cables in the switch box?
Not necessarily.
220/221 is offline   Reply With Quote
Old 05-12-2009, 01:01 PM   #6
Not wanting give an answer,(I'm not a pro) I'll ask a question. Since power is already going to the switch, couldn't cshsr cut out the single gang box and then install a 2-3 gang old work box to then service the fan/light and recptacle?
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 05-12-2009, 01:10 PM   #7
Ideally, this is the way to do it.
But....you must have power AND a neutral at the sw box.
Sometimes you will have a suicide switch (two wire switch loop) in the box with a white hot and a black sw leg.
That's when you have to go to plan B.
Old 05-12-2009, 01:20 PM   #8
I forgot about that scenario. See, that's why I asked instead of just answering.
Old 05-12-2009, 02:59 PM   #9
OK, I'll bite....why is it called a "suicide switch"? A switch loop like that is code, right, even though it's not ideal....?
Burbman is offline   Reply With Quote
Old 05-12-2009, 03:36 PM   #10
joed's Avatar
Switch loops are code compliant. I have never heard them called suicide switches before.
Old 07-20-2009, 05:08 PM   #11
on the outlet i have (2) white , (1) black and a ground. At the switch I have (1) white , (1) black and a ground.
Installing a ceiling fan with a light switch. Unregistered Electrical 9 08-23-2011 04:36 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 06:53 PM
Confirming light switch wiring Chris_Von_Bron Electrical 4 12-08-2007 07:42 PM
