-   -   wiring ceiling fan to light switch (http://www.diychatroom.com/f18/wiring-ceiling-fan-light-switch-44338/)
cshsr 05-12-2009 07:20 AM
I have a ceiling fan with a light package that I am installing in a room with no light fixture. The light switch in the room controls a wall socket only. Can I wire this from the light switch
J. V. 05-12-2009 11:35 AM
Does the switch control more than one receptacle? If it does you will have to sacrifice all but one of them for the fan and light. Switching that is.
The best way to go is to fish a 3 conductor cable from the switch up into the attic and into a fan box. This way you can control the fan and light independently.
I would think it will be easier to fish the cable up through the switch box than it would the receptacle. But I am not the one going fishing, you are. Good luck. :thumbsup:
cshsr 05-12-2009 11:51 AM
When you say 3 wire you mean one with white , black and red leads? the switch only controls one outlet.
joed 05-12-2009 11:52 AM
If you want to wire the fan into the light switch then you have give up the switching capability of the recpetacle. The receptacle will have to always on.
http://www.selfhelpandmore.com/switc...switched-plug/
220/221 05-12-2009 11:52 AM
Maybe.
You may have to rewire and sacrifice the half switched recep.
How many wires/cables in the switch box?
Not necessarily.
beer_geek 05-12-2009 12:01 PM
Not wanting give an answer,(I'm not a pro) I'll ask a question. Since power is already going to the switch, couldn't cshsr cut out the single gang box and then install a 2-3 gang old work box to then service the fan/light and recptacle?
220/221 05-12-2009 12:10 PM
Ideally, this is the way to do it.
But....you must have power AND a neutral at the sw box.
Sometimes you will have a suicide switch (two wire switch loop) in the box with a white hot and a black sw leg.
That's when you have to go to plan B.
beer_geek 05-12-2009 12:20 PM
I forgot about that scenario. See, that's why I asked instead of just answering.
Burbman 05-12-2009 01:59 PM
OK, I'll bite....why is it called a "suicide switch"? A switch loop like that is code, right, even though it's not ideal....?
joed 05-12-2009 02:36 PM
Switch loops are code compliant. I have never heard them called suicide switches before.
cshsr 07-20-2009 04:08 PM
wiring ceiling fan
on the outlet i have (2) white , (1) black and a ground. At the switch I have (1) white , (1) black and a ground.
