Wiring For Ceiling Fan/light With Dual Switch At End - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 09:52 AM   #16
Rewards Points: 512
also, what do you mean by "dual switch"?
Old 10-22-2010, 10:00 AM   #17
47_47's Avatar
Rewards Points: 82
Originally Posted by Jim Port View Post
The power in black will splice to the white in the B/R/W cable and will supply the power to the switch. The black and red will be the switch controlled hots that will splice to the fan and light wire from the fan, one to each.
The fan white will splice to the white from the power in cable.
All grounds together.
The power feed to the switches will need to be re-identified with black or red tape or magic marker as a hot conductor.
Follow Jim Port's advice
47_47 is online now   Reply With Quote
Old 10-22-2010, 10:05 AM   #18
I am in US.
Here is my interpretation of Jim's Post. It looks like it will work fine to me.
http://yfrog.com/7cwiringp
Thanks to all
mcherno925 is offline   Reply With Quote
Old 10-22-2010, 10:16 AM   #19
Just call me Andrew
Rewards Points: 1,020
The switch probably has wires from the factory, as does the fan. He never said his 14/3 has a blue wire.
Jim's original response is perfect. Just don't forget to re-identify that white in the 14/3 as hot with tape or a marker (any color other than white, green, or gray).
Just saw your diagram, looks fine except you need to re-identify that white as hot in the switchbox as well (do it the same way on both ends). It also still says your switch needs a neutral
Andrew
secutanudu is offline   Reply With Quote
Old 10-22-2010, 10:21 AM   #20
47_47's Avatar
Rewards Points: 82
Here is one of Stubbies diagrams.
http://www.dropshots.com/stubbie4#al...09-04/19:07:31
Old 10-22-2010, 10:37 AM   #21
Rewards Points: 330
then if he has red,blue,black at sw,someone taped white blue...also if this is old work,neutral not required.that is 2010-2011 code change.other wise he will have to run at least a 14-2 from fan box to switch.
oleguy74 is offline   Reply With Quote
Old 10-22-2010, 10:54 AM   #22
Just call me Andrew
The SWITCH probably has a blue wire on it. NOT his 14/3.
Andrew
Old 10-22-2010, 11:09 AM   #23
Rewards Points: 330
well then where did the blue wire at sw come from?
Old 10-22-2010, 11:11 AM   #24
Just call me Andrew
The factory....
Andrew
Old 10-22-2010, 11:21 AM   #25
Rewards Points: 330
Originally Posted by mcherno925 View Post
CHUTE! Sorry, my OP was incorrect which may have caused the confusion -- there is no white wire in the switch, just red blue black and ground. Given that, will the first reply work?
this is what i am talking about.the 14-3 from fan box to sw,white has ben colered blue.whay don't you under stand?
Old 10-22-2010, 11:24 AM   #26
Just call me Andrew
He still did NOT say that the 14-3 has a blue wire in it! The switch came pre-wired with 4 conductors...
Andrew
Old 10-22-2010, 11:41 AM   #27
Rewards Points: 330
ok my bad.one of the wires,red or black will be hot in.blue will be fan,black or red will be fan.you may have to go to the store and get inst or there may be labels showing hot in,fan lite out.look on back of sw.hot in will say common.most likely black.forth wire is green for ground wire in 14-3.
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
Impossible switch wiring configuration? Ptron Electrical 13 09-07-2010 01:47 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 02:39 PM
