Wiring Ceiling Fan---HELP!! - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2007, 12:40 PM   #1
wires coming out of ceiling is black, white and red
wires in celing fan is black, white and blue
there are two switches controling the ceiling fan......one light switch is a single switch by itself on one wall.... the other is a two switches one w/ a 'dimmer' knob to turn on the ceiling fan and control the speed, the other is a single light switch on the other wall........
how do i rewire this.......black to black , white to white and red to blue did not work.......the light does not work when i do that.....
thanks
jcmzhou is offline   Reply With Quote
Old 09-02-2007, 01:48 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Have you touched any wiring other than the ceiling box wiring? Your connections are the correct convention for independent control of the light and fan.
I am assuming that the fan control is working the fan correctly?
The light bulb is good?
Is the light supposed to be controlled from the other two switches excluding the fan control?
In other words are the other two switches 3 way switches?
Stubbie
Old 09-02-2007, 02:26 PM   #3
i have not touch or messed with any of the boxed wiring
yes is it
yes
yes, the two other switches control the fan light as well as a wall outlet......i replaced on old ceiling fan and did not pay attention to the way they had it wired.......before i did this one, it put up the same model fan in a bedroom (which was on a single switch), i then wired the living room fan the same and the light did not work, not realizing the loop switches that controlled the light
yes
Old 09-02-2007, 11:38 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Well only thing to do is test that red wire at the ceiling for switched voltage. It should have voltage when tested with a voltage tester to the white wire or ground wire with either 3 way switch in the 'on' position then no voltage when in the off position. If it has voltage then you have a problem at the ceiling fan lighting dome circuit. If it has pull chains see if the switch is bad or off.
Stubbie
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
My ceiling fan wiring problem jkrodger Electrical 9 08-13-2007 03:51 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
Wiring Ceiling Box to Switch graceandhayes Electrical 1 10-23-2006 05:02 PM
Ok to run wiring between strapping in the ceiling? peeks Electrical 5 08-29-2005 12:12 AM
