-   -   Wiring ceiling fan from end of run switch (http://www.diychatroom.com/f18/wiring-ceiling-fan-end-run-switch-149603/)
ledergoster 07-08-2012 06:34 PM
I am installing a ceiling fan in my daughter's bedroom (fan only, no light). There is currently a switch that powers an outlet in the room, and the switch appears to be end of run (one 2 wire cable plus ground into switch box). I want to use this wire to power the fan independent of the switched outlet.
I've expanded the box to 2-gang and added the second switch. I can run a new wire from switch box to ceiling fan location. I can also pull back the current wire to stop at the ceiling fan before coming into the box if needed. Either way I can't get the ceiling fan switch to be independent of the switched outlet.
Any help would be appreciated.
kbsparky 07-08-2012 06:36 PM
The existing wire can NOT be used to power another load. You will have to feed the fan independently of the existing devices.
ledergoster 07-08-2012 07:19 PM
Thanks for the quick reply.
"The existing wire can NOT be used to power another load."
Is this because of the potential load on the circuit for the room (15A circuit, 4 outlets in room, no other devices), or because of the position of the wire in the run? Just trying to understand.
Thanks.
kbsparky 07-08-2012 08:15 PM
Neither. It's because you do not have a neutral conductor present in a 2-wire switch loop.
ledergoster 07-08-2012 08:49 PM
Got it now. Thanks.
On to plan B (whatever that is...).
k_buz 07-08-2012 08:59 PM
You can most likely change that two wire from a switch loop to a feed, but you would have to install a light kit on the fan to meet code.
