Wiring A Ceiling Fan In A 1950's House - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 09:14 AM   #16
Rewards Points: 1,442
Handy to have: a multimeter (combination voltmeter ohmmeter) and a long single conductor wire, 14 to 18 gauge best to reach from where you are working over to a place you are using for a test expected ground or a test expected neutral.
Always turn the power off before using the ohms (continuity) function of the meter.
Old 01-01-2011, 10:12 AM   #17
Household Handyman
Rewards Points: 1,408
With that older wiring I'm betting: The two wires tied together are a "HOT" wire feeding a wire to the switch, the other wire is the "return" from the switch to the light, fan, etc. As stated, this is rental property, not your problem. Talk to the landlord and see if you can work out something so he/she will furnish an electrician for this.
Old 01-01-2011, 05:10 PM   #18
Originally Posted by bob22 View Post
IF you get something like this (from HD; similar at other stores):
http://www.homedepot.com/Electrical-...atalogId=10053
You can touch the probe end to one wire and the other probe to the other: if light lights, you've got power. Should be able to see which one is neutral (white wire) by then touching one probe of meter to metal of ceiling box or ground wire and the other probe to each of the two wires you've got coming out of the ceiling (one at a time). If light lights on one of these tests, then the ceiling wire that lit the lamp should be the "hot" (black) wire.
Per Bob's suggestion, I tried a meter and single wire coming out was hot the other two twisted together were not. The fan is back up and working properly.
Thanks for your help and suggestions.
chrispund is offline   Reply With Quote
Weird wiring in house fdmillion Electrical 13 06-14-2013 07:49 PM
Ceiling fan wiring CalicoGuy Electrical 3 06-02-2010 07:40 PM
Ceiling fan installation; old house wiring not standard agisoec Electrical 5 04-18-2010 06:57 PM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 09:14 AM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
