Wiring A Ceiling Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 10:31 PM   #1
wiring a ceiling fan
I am replacing a ceiling fan that had three switches on a wall plate. One controlled the fan, one controlled the light and the third controls a wall outlet. My new (from my old house) fan is a remote controlled fan. I keep tripping the breaker any way I wire it. There are three romex wires coming into the switch box. All three white wires are twisted together, all three black wires are twisted together then split off to each switch. there are only two red wires that come into the box and one goes to the switch for the outlet and the other goes to the center switch. I am using the far left switch only to connect the remote wall switch. there is a black wire coming in from the wall to one end of this switch and a black wire coming from the other bundled black wires. I am not using the two wires that used to go to the center switch. In the ceiling I have one red, one white, and one black wire coming out. I am connecting the "AC Line N" to the White wire, and the "AC in L" to the black wire. Neither the fan nor the light is working and I keep blowing the breaker with any other combination of wiring. All ground wires are connected properly. PLEASE HELP????
cantlon is offline   Reply With Quote
Old 11-13-2012, 10:52 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
From what you describe, I don't believe it is how you wired the switches. How did you wire the fan itself?
Be aware, if you shorted out the circuit, the wall controller or the receiver may have went bad.
Old 11-14-2012, 08:13 AM   #3
In the ceiling I have one red, one white, and one black wire coming out. I am connecting the "AC Line N" to the White wire, and the "AC in L" to the black wire and ground to ground all to the remote box in the ceiling fan. I then connected the remote to the fan color to color.
Old 11-14-2012, 10:01 AM   #4
BY the way, i also bought a new remote and switch and as soon as I turned the power switch (on the switch) the breaker blew.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 08:48 PM
Wiring A Porch Ceiling Fan TFSpaniel Electrical 14 07-23-2011 12:04 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
