Old 01-23-2012, 10:50 PM   #1
Wiring a ceiling fan
My ceiling fan in my room will not turn light off on the fan. I have to turn off at the wall switch . Should I run a 3 wire from switch to fan to have a continuos Hotwire
Gardec is offline   Reply With Quote
Old 01-23-2012, 10:55 PM   #2
I'm Your Huckleberry
No, you buy a fan that has two switches on it. Both the fan and the light use the single hot provided. If you currently have a hot, neutral and a ground than that's all you need.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-25-2012, 06:47 AM   #3
Yes, you can run 3 wire from switch to fan to have a continuos Hotwire.
agate is offline   Reply With Quote
Old 01-25-2012, 08:29 AM   #4
MarginallyQualified
Did the fan EVER turn off using the switch at the fan?
They're convenient to have but a major PITA to add later...
In any case, no... the reason to 3wire is to have BOTH light and fan switch's by the door.
Old 01-25-2012, 08:39 AM   #5
PoleCat's Avatar
Sometimes it is so you can turn the light off at the wall but still have the fan operable. (like at night)
PoleCat is offline   Reply With Quote
Old 01-25-2012, 11:03 AM   #6
MarginallyQualified
and your point is?
Old 01-25-2012, 11:35 AM   #7
Stuck in the 70's
Blondesense's Avatar
First, let me say I'm no expert, and have minimal electrical knowledge, but I seem to remember hearing some cities' building codes require the light to be controlled from a switch near the door.
Old 01-25-2012, 12:00 PM   #8
PoleCat's Avatar
and your point is?
This is a common situation where the fan is controled soley by the pull chain rather than a switch at the wall. Most common in older homes that are fed at the ceiling box too.
Old 01-28-2012, 12:09 AM   #9
My ceiling fan will only turn on at the fan switch when the wall switch is on I want to be able to use the fan for either, but it only has a black and white only should a run a three wire w a red wire to do this .
Old 01-28-2012, 08:37 AM   #10
PoleCat's Avatar
Yes, if that is the easiest thing to do. You need an unswitched hot wire in your ceiling box for the fan.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 08:48 PM
Wiring A Porch Ceiling Fan TFSpaniel Electrical 14 07-23-2011 12:04 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
