Wiring From On Building To Another - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2009, 03:10 PM   #1
geeze I just asked!
Send a message via Yahoo to desertkitty
wiring from on building to another
We bought some property out in the middle of no where! there is a camping trailer on one section that has electric to it. there is also a mobile home trailer on the property about 300 ft away. the trailer needs to be remodled and doesnt have any electric to it. we had the electric company out and they want $4k to do a new hook up. We cant afford that. we want to tap into the electric thats already there and use that. I have done electrical/construction work with my father years back but hes not here for advice anymore. I know I need to bury conduit and all that. But what I am stuck on is what size and type wire to use. and how to tap into it next to the camper. I know this is a unique situation. any help would be appreciated. safety is my biggest concern. really need some soound advice.
desertkitty is offline   Reply With Quote
Old 01-22-2009, 05:08 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 330
Ayuh,..
Somewhere around that Camper is an Entrance, Meter,+ Breaker Box...
You need to decide if you're going to run from the breaker box,+ how many amps you need in the new sub-panel...
Then you can figure out how heavy a wire,+ how to protect it from 1 box to the other...
Of course, you're limited by the size, in amps, to what's at the main entrance box...
Btw,... I'm not an Electrician,+ My advice should be taken with a grain of salt.....
Flame Away....
Bondo is online now   Reply With Quote
Old 01-22-2009, 10:01 PM   #3
Electrician
ctsmiths's Avatar
Rewards Points: 150
Buy a generator.
ctsmiths is offline   Reply With Quote
Old 01-23-2009, 02:59 AM   #4
geeze I just asked!
Unhappy
well...
we have one but its not a good enough answer for long term. need more stable power. christ gas has been killing me.
Old 01-23-2009, 09:05 AM   #5
Rewards Points: 1,418
I would run a 120/240 volt line aka multiwire branch circuit.
I would use one size larger wire than normal given the distance.
For example #10 wire carries 30 amps. so I would run #8.
Or #8 wire carries 40 amps so I would run #6 for that much current needed.
I would plan ahead for the future in choosing wire size, even though the line might be protected with smaller than allowable breakers pending upgrade of the main panel and service.
I would like to string individual conductors (4 including the needed ground) overhead (if there are trees for support) rather than dig a trench but I would need to look up the code (NEC) to see how or whether I can do that.
In addition to separate ground and neutral going back to the main service, you need a ground rod out there.
Old 01-23-2009, 05:43 PM   #6
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Run an underground feeder from the existing service to the mobile home service. A 4 wire, direct buried or in conduit. Wire size would depend on how much power you want to install. Connect to a 2 pole circuit breaker in the existing box and run to the mobile home panel if there is one.
For instance #2-2-2-4 wire aluminum mobile home feeder will do the job and provide about 50 amps at that distance. Larger wire will provide more power without a unacceptable voltage drop. Copper is very expensive in these lengths.
http://buyawg.thomasnet.com/viewitem...inum-conductor
This will get you started. Provide more info to get more ideas and details.
John
jrclen is offline   Reply With Quote
Old 01-23-2009, 10:42 PM   #7
Electrician
ctsmiths's Avatar
Rewards Points: 150
I hear that, I was just kidding anyway.
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 01:19 PM
wiring a storage building 1arry Electrical 2 07-25-2008 12:13 PM
Building wiring fault jaasman Electrical 7 03-19-2008 08:07 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
