Wiring A Box With A Switch And Dimmer - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 10:03 PM   #1
Question
Wiring a box with a switch and dimmer
I have a box with a switch and dimmer. I am replacing both, but failed to label my wires when I removed them(big mistake...).
The switch operates light 1, the dimmer operates light 2, and power gets passed out to another box with a switch for light 3.
I have four sets of wires coming into the box, only one set has a live black wire when not connected.
I also have a loose piece of black wire that I believe was used between the switch and dimmer.
I am not sure exactly how to rewire this set up.
Any suggestions??
Thanks in advance.
ss3251 is offline   Reply With Quote
Old 11-09-2011, 10:42 PM   #2
Licensed electrician
Rewards Points: 1,296
With 4 cables it sounds like power in, power out and the 2 cables to the two lights. Once you identify the hot should should be able to make the lights work by temporarily connecting one of the black to the hot and see which light now works. Repeat to find the second light. Only make any connections with the power off.
ss3251 (11-09-2011)
Old 11-09-2011, 11:01 PM   #3
Thank You!
That sounds right.
So, Would I...
1.connect all four white wires together?
2.connect black going in with black going out to next box, along with a wire going to the switch and a wire from the dimmer?
3.Then connect the othe two black wires that come in from the lights to the switch and dimmer, respectively?
(and yes, I am making all connections with the power off )
Old 11-09-2011, 11:14 PM   #4
Sounds right.
You should not have needed to make any changes to the white while replacing the switches.
ss3251 (11-09-2011)
Tags
wiring problem
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Dimmer switch wiring question joez148 Electrical 2 07-15-2010 11:49 AM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
Different wiring on replacement dimmer switch kmmccorm Electrical 2 01-09-2010 07:48 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
