Wiring A Boiler - 15 Or 20 Amps? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 09:41 AM   #1
Just call me Andrew
Rewards Points: 1,020
Wiring a boiler - 15 or 20 amps?
I want to add an emergency shutoff for my boiler at the top of the stairs. There is this old-style shutoff (pic attached) right above the boiler, but I don't like not having one at the top of the stairs. I plan to just wire the switches so that both need to be on for the boiler to get power.
This circuit is a 15A circuit currently. It's an early 90's oil-fired boiler, right next to the panel. Do newer gas boilers (which is what I will be swapping to within the next few years) be ok on a 15A circuit? If not, I'll run 12/2 across my basement to the new shutoff. If a dedicated 15A circuit is fine for a newer boiler, I'll go with 14/2.
Suggestions?
Andrew
secutanudu is offline   Reply With Quote
Old 10-05-2010, 12:08 PM   #2
DIYer
15 amps should be fine, unless you have an exceptional boiler.
Gigs is offline   Reply With Quote
Old 10-05-2010, 01:50 PM   #3
Just call me Andrew
I just opened up that switch I pictured above, I didn't realize there are fuses in it. It's a little 2-pole 30-amp (?) shutoff...can I just remove it? The circuit is on a single 15A breaker anyway...those fuses could never do anything. I posted some pics below.
I assume I can just wire the boiler directly from the breaker, right? I will just replace that fused switch with a normal 15A switch with the red cover plate, and wire that switch in series with the one at the top of the stairs.
That make sense? I don't see any need for a neutral in the upstairs switchbox....so I plan on just doing it as a switch loop.
Wiring a boiler - 15 or 20 amps?-1005101438.jpg   Wiring a boiler - 15 or 20 amps?-1005101436.jpg
Andrew
Old 10-05-2010, 01:57 PM   #4
DIYer
Instead of a light switch, I would use a "pull out" style disconnect like air conditioners have. They are pretty inexpensive.
Light switches aren't really good for motor loads unless you get one rated for it.
Old 10-05-2010, 02:32 PM   #5
My boiler is on a 12g 20a circuit
Its 22 years old
Not sure on what the recirc pump pulls
Old 10-05-2010, 02:37 PM   #6
OK...I had to go & check
My recirc pump takes .75a
My oil burner takes 2.4a
Old 10-05-2010, 04:36 PM   #7
Just call me Andrew
Example? Never heard of that before...What light switch WOULD be rated for motor loads? A heavy duty 20A one?
Andrew
Old 10-05-2010, 05:04 PM   #8
Rewards Points: 266
Don't worry, standard 15 A switches will be fine for your boiler.
junkcollector is offline   Reply With Quote
Old 10-05-2010, 05:07 PM   #9
Every boiler shut-off I have seen is just a light switch
Old 10-05-2010, 05:12 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I completely agree. IMO a pullout for a 15A/120v boiler circuit is absurd.
Old 10-05-2010, 05:20 PM   #11
Just call me Andrew
Great, thanks. And I can replace that 30A old fused disconnect with a light switch also, right?
Andrew
Old 10-05-2010, 05:45 PM   #12
liscenced electrician
Rewards Points: 538
agreed. Saying a switch wont work for this is like saying a bath fan needs a pullout disconnect to shut it off
jimmy21 is offline   Reply With Quote
Old 10-05-2010, 07:37 PM   #13
" Euro " electrician
frenchelectrican's Avatar
Ya don't need to go overboard with disconnect switch the standard toggle switch will suit just fine for this useage.
Just make sure if you going to run new switch get red switch cover plate say " boiler disconnect " some case " oil burner disconnect " one of the two but few local codes may stated " Gaz burner disconnect " as well.
Here the photo look like.
Merci.
Marc
Old 10-05-2010, 07:43 PM   #14
Just call me Andrew
Thanks guys. I already bought the red emergency cover plate, Marc.
Andrew
Old 10-06-2010, 04:22 PM   #15
DIYer
<edited to remove wrong info>
I looked it up and actually it is OK to use a normal light switch for motors under the following conditions:
"A general-use snap switch where the motor full-load current rating is not more than 80 percent of the ampere rating of the switch."
So now I know better.
Cost of boiler & cylinder replacement abaminog Off Topic 9 03-31-2010 07:05 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Need Help I Have a BOILER PROBLEM mikerouse1989 Plumbing 7 02-01-2009 05:07 PM
Boiler Troubles *I Need Help Please* mikerouse1989 HVAC 4 02-01-2009 11:59 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
