Wiring For Blower AHU - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 04:35 PM   #1
wiring for blower AHU
I'm replaicng the AHU for my central AC system. The unit specs are for a 208/240 Volt , 1 phase, 1.0 HP, 6.9 FLA. My questions are:
*What size breaker is required, 1 pole or 2 pole?
*what size wire and how many conductors 3-wire (black, white, red, green) or 2-wire (black, white, green)?
thanks
rcassidy is offline   Reply With Quote
Old 04-05-2012, 04:50 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
Well, sicne it is 240v you obviously need a two pole breaker.
12/2 is fine for this as it is a straight 240v circuit that does not require a neutral. The white can and should be re-marked as a hot with a permanent marker. Black, blue or red is typical.
Old 04-05-2012, 04:52 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
thanks
You need a 2 pole breaker. You need a 2 wire cable (black, white (remarked to black), bare ground) or 3 wires in conduit ( 2 Black (or red), 1 green). You do not need a neutral, which is normally the white wire.
Breaker amperage should be specified on the rating plate.
Coastal South Carolina
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 11:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
