Wiring Behind Studs - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 05:57 PM   #31
Thanks for the inputs.
The slack is a reminder of a time when a rotozip/dremel
sliced the romex. Didn't want this to happen again.
So from the picture,
1) if the gang box was instead a metallic box:
i would have 8" + 2" = 10"
so thats within the 12".
2) if plastic box used, with "ORANGE" color
i would have 6" + 2" = 8"
so thats within the 8".
hope this have been interpreted correctly?
georgeo is offline   Reply With Quote
Old 07-24-2010, 06:01 PM   #32
It must be secured within the required distance measure along the wire
You can't have 14" of wire secured within 8" of the box
Old 07-25-2010, 03:12 AM   #33
Totally screwed together
Yes, the orange would satisfy. You could also just tack in another staple just ahead of the other one so you are catching the romex at 6" from the box. The would immediately make the existing wire legal.
xxPaulCPxx is offline   Reply With Quote
Old 07-25-2010, 09:42 AM   #34
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
In that image, why not just add a staple hitting BOTH cables at around 5"?
Problem solved.
Old 07-25-2010, 10:04 AM   #35
Licensed electrician
Rewards Points: 1,034
Problem solved
Or just get better drywallers.
Old 07-25-2010, 10:31 AM   #36
Electrician
Proby's Avatar
I think you are overthinking this. Staple the wire and close up the walls, then enjoy your room
Proby is offline   Reply With Quote
Running wire to box between two studs Eclipse99 Electrical 6 03-22-2010 06:20 PM
Studs too close together for structured wiring panel juengl4 Building & Construction 15 12-25-2009 10:52 AM
Through or over studs for wiring? BasementVirgin Electrical 6 10-05-2009 09:59 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
What's code for wiring distance from end of studs? Webguy64 Electrical 2 07-17-2007 06:58 AM
