Wiring Behind Studs - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-04-2010, 12:27 PM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Originally Posted by fortop View Post
Drilling through studs is the normal procedure, and I think 3/4" protection for the romex is minimum required.
Holes must be 1-1/4" from the edge of framing for protection.
Old 07-04-2010, 01:35 PM   #17
Will put a steel plate at location 1.
Is a plate needed if the staple is less
than 1 1/4" from the face or front of
the stud as in location 2?
- Think its roofing asphalt that was put
onto the wall, then a 2 x 2 spacer thats
secured to the back of the 2x4 studs.
Not sure why there's a gap between the
2x2 spacer and cement wall.
Wiring behind studs-pic-2-inch-cement-wall.jpg   Wiring behind studs-pic-staple2.jpg
georgeo is offline   Reply With Quote
Old 07-04-2010, 01:39 PM   #18
OK, but it is only needed if the hole is less than 1-1/4" from the edge.
Again yes. BUT..... there should be NO reason that holes or stapled wires are less than 1-1/4" from the finished edge in your situation.
Old 07-11-2010, 12:53 PM   #19
Answer for FORTOP question:
The 2x2 horizontal strapping at the bottom (about 6 inches of the floor)
behind the studs is temporary there,
so that after putting the felt onto the wall,
there would be a long continuous horizontal strapping to hold the
black felt onto the wall.
From the pic:
Is it ok to wire the outlet this way? thanks.
Old 07-11-2010, 09:57 PM   #20
Rewards Points: 1,910
Hi Georgeo, I don't know if it's ok per code but I wouldn't leave that big loop and all that excess wire there. Where it comes through the stud just run it straight down to the box and secure it to the side of the stud (towards the back) with a couple staples.
That's a lot of wires running through that wall.
Old 07-11-2010, 10:31 PM   #21
Registered User
Rewards Points: 5,514
http://www.diychatroom.com/f19/frami...-strips-75873/
Be safe, Gary
Old 07-15-2010, 09:09 PM   #22
Thanks GBR in WA -- and will check out links.
Thanks jogr: Will update the wiring according to the pic.
re: That's a lot of wires running through that wall.
Can you provide some insight on what could be wrong
with a lot of wires running through that wall?
The wires are for washer, dryer outlet, ceiling lights,
furnace wiring, etc...
Is there a way to wire the outlet having extra
slack?
Old 07-15-2010, 09:16 PM   #23
No real problem with lots of wires thru a wall
Most people try to group them in one area
--such that the area can be avoided when driving in nails etc
Old 07-16-2010, 08:14 AM   #24
joed's Avatar
Rewards Points: 12,872
Why do you need extra slack in the wire? Are you planning to move it later?
Old 07-16-2010, 08:58 PM   #25
Can the outlet be futureproofed so as to have the extra slack
for any future duct work, home theater speakers or anything else in the way.
Minimal distances within the box are under 300.14.
Any suggestions? thanks.
Old 07-16-2010, 11:47 PM   #26
Totally screwed together
Loop or accordian the wire up and use a ziptie with a fastener hole to cinch it tight together, so that none of it is closer than 1.25" to the surface. Do this within 8" of where you are placing the box.
xxPaulCPxx is offline   Reply With Quote
Old 07-23-2010, 07:49 PM   #27
If i use a ziptie with a hole in it,
can i make 2 loops or whatever amount
of loops for slack and be within 8 inches
of the box or is that a Big NO-NO ?
Attached is pic with 1 loop.
Thanks.
Old 07-23-2010, 08:05 PM   #28
Do it like xxPaulCPxx says and it is legal.
BTW, both of those pictures are violations.
What is the obsession with these loops anyway?
Old 07-23-2010, 09:41 PM   #29
Because a DIY has to plan for all permutation of the room, not just the plans the architect gave them. If that box ever needs adjusting, he has the slack without having to pull new romex. Sure, Speedy Petey would be able to whip that new romex run out in a mere 30 seconds... which takes a DIY like me about 30 days to do the same thing
The staple has to be attaching the wire to the stud within 8" (I can't remember the distance off the top of my head. As you have it currently set up, the staple is securing the romex about 2' away from the box!
Old 07-23-2010, 09:54 PM   #30
For the record, it is within 8" of a single gang non-metallic box with no clamping means. All others it is 12". These numbers are measured along the wire, not in a straight line.
Running wire to box between two studs Eclipse99 Electrical 6 03-22-2010 05:20 PM
Studs too close together for structured wiring panel juengl4 Building & Construction 15 12-25-2009 09:52 AM
Through or over studs for wiring? BasementVirgin Electrical 6 10-05-2009 08:59 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
What's code for wiring distance from end of studs? Webguy64 Electrical 2 07-17-2007 05:58 AM
