Wiring Behind Studs - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 09:12 PM   #1
Wiring behind studs
In an unfinished basement, is romex allowed to be
be run horizontally behind studs (holes are not bored into the studs)?
The framing is offset by about 2 inches from the
cement wall. Looks like the wiring is supported only by friction at a
90 degree turn in the wall.
georgeo is offline   Reply With Quote
Old 06-28-2010, 09:15 PM   #2
joed's Avatar
Rewards Points: 13,750
It is allowed but it still need to fastened every 4 feet.
Old 06-28-2010, 10:06 PM   #3
Thanks Joed.
Would the corner stud be condidered as a
end point (eg. starting point then measuring
4 feet on either wall direction and stapling
at the rear of the stud)?
Is the wiring method worth keeping
or should it be replaced with boring studs?
Old 06-28-2010, 10:45 PM   #4
It needs to be secured every 4' including going around the corner
Friction does not meet code
The Following User Says Thank You to Scuba_Dave For This Useful Post:
georgeo (07-04-2010)
Old 06-28-2010, 10:47 PM   #5
joed's Avatar
The corner stud is only considered a starting point if the cable is fastened to it.
If it is existing no need to change it. I would not do it that way however. It's no big deal to drill holes.
Old 06-28-2010, 11:02 PM   #6
Rewards Points: 1,910
Since it will be hard to place staples on the back side of the studs (with only a 2" gap) and a pain to drill and repull the wires is it ok for him to:
Tack in a wiring staple to the side of the stud near the back edge (leaving it 1/8" to 1/4" proud) and then zip tie the wire to the staple.
Or does code require specific fasteners?
Old 06-30-2010, 03:26 PM   #7
Would stapling to the side of the stud every 4'
pass code? Is this method of wiring behind
studs considered "amateur" and technically incorrect?
Thanks.
Old 06-30-2010, 03:37 PM   #8
joed's Avatar
I consider it amateur. I don't know if it will or will pass code.
The Following User Says Thank You to joed For This Useful Post:
Old 06-30-2010, 04:07 PM   #9
Licensed electrician
Rewards Points: 1,892
I don't see why this method would not be acceptable.
If listed materials are used they must be used as listed; ie correct number of cables per staple, correct size ranges etc.
Old 06-30-2010, 10:51 PM   #10
Here's some official electrical zip ties
http://www.elecdirect.com/catalog/7a...FQLEsgoduh7hyA
The Following User Says Thank You to jogr For This Useful Post:
Old 07-01-2010, 08:21 AM   #11
Anyone have any pics of using the electrical ties in practice?
Can Ramset-ing a piece of plywood to the cement wall every
4' and then stapling romex onto the plywood is
code passable...It is shoddy work.
Old 07-01-2010, 09:07 AM   #12
If those studs are 2' OC you could just drill every other one to secure the cable. you are not talking about any time to drill a few holes.
Old 07-01-2010, 05:37 PM   #13
Drilling through studs is the normal procedure, and I think 3/4" protection for the romex is minimum required. But, I think stapling to pieces of plywood ramset into the wall has the additional advantage of providing more protection from future nail penetration (hanging cabinets, pictures,etc.) than drilling through the center of the stud. It does seem like unnecessary extra effort. Some people run short lengths of conduit when furring out masonry walls with studs up to 8' vertrically, then make the horizontal runs in the overhead floor or ceiling joists.
fortop is offline   Reply With Quote
The Following User Says Thank You to fortop For This Useful Post:
Old 07-04-2010, 12:10 PM   #14
Thanks for all input.
From the picture, does it look ok?
Old 07-04-2010, 12:19 PM   #15
Is that felt paper over a masonry wall, then a 2 x 2 spacer, then a 2 x 4 stud wall?
Running wire to box between two studs Eclipse99 Electrical 6 03-22-2010 05:20 PM
Studs too close together for structured wiring panel juengl4 Building & Construction 15 12-25-2009 09:52 AM
Through or over studs for wiring? BasementVirgin Electrical 6 10-05-2009 08:59 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
What's code for wiring distance from end of studs? Webguy64 Electrical 2 07-17-2007 05:58 AM
