Wiring Bathroom Fan Timer - Connections - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 05:58 PM   #1
Hi, I wish to wire a timer in place of the on/off switch that powers my bathroom exhaust fan. The timer I've purchased has three wires: black, white and blue. The switch that I wish to replace has two wires only and both have been painted either because someone was careless or to designate special use. One wire attaches to the switch terminal as normal, while the other wire has had insulation removed at a point on its length and the resulting bare wire looped around the second switch terminal on its way to a junction with several other wires.
Could someone advise me if I can still wire the timer into this circuit and if so, how.
Thanks.
Jim
Trick46 is offline   Reply With Quote
Old 06-24-2009, 05:59 PM   #2
What do the directions for the timer say to do?
Old 06-24-2009, 06:50 PM   #3
I've uploaded a scan of the wiring diagram. I should add that that the switch box holds three switches; the other two run the bathroom lights.
Jim
Old 06-24-2009, 06:54 PM   #4
The existing wire that also connect to multiple wires should be the line feed. That would be the black wire on the timer. The blue wire would attach to the other existing wire on the switch
Now comes the problem, it indicates it needs a neutral connection
Your exisiting switch is only a hot loop
So you would need a neutral in that box for the white wire on the timer
Any chance this is run in conduit
Old 06-25-2009, 02:15 PM   #5
Scuba_Dave, thanks for all of your help. I've pulled the three switches out of the box and attached photos of the wiring layout. Could you take a look and confirm for me which of the timer wires should be attached to what connection. The switch that I'm replacing with the timer is the one on the right. Thanks.
Jim
Wiring Bathroom Fan Timer - Connections-img_2724.jpg   Wiring Bathroom Fan Timer - Connections-img_2725.jpg
Old 06-25-2009, 03:35 PM   #6
The bottom wire on the switch (closest to the wall) is the hot feed
That loops to the other switches
The black wire from the timer should attach to this
The other wire (top of switch) goes to the device
The blue wire from the timer goes to this wire
The white wire from the timer goes to the 3 white wires that are twisted together & capped
Old 06-25-2009, 04:47 PM   #7
Worked like a charm! Thanks very much for your instructions. My wife thanks you too!
Jim
Help with digital timer wiring longman Electrical 7 12-06-2008 11:22 AM
Wiring Problem in Bathroom notasparky Electrical 7 10-27-2008 06:34 PM
Help with electrical timer wiring Jack417 Electrical 2 07-05-2007 02:26 PM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
