Wiring A Bathroom Exhaust Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2007, 06:47 PM   #1
Lost in Space
wiring a bathroom exhaust fan
Do they make a switch that senses humidity and will turn on a bathroom exhaust fan automatically? My wife and kids are apparently alergic to the fan switch and never seem to remember to turnon the fan.
Thanks,
Tool Junkie is offline   Reply With Quote
Old 09-26-2007, 06:52 PM   #2
C+M Electrician
humidistat
you could wire in a line voltage humidistat but they tend to be extremely unreliable, you're better off wiring the fan into the lights for the shower.
SparkyInCanadaEh is offline   Reply With Quote
Old 09-26-2007, 07:05 PM   #3
Lost in Space
The only problem I see what that is that they will shut the light off after they leave the batroom and the fan will stop...never mind, Im the only one who shuts off lights!
Old 09-26-2007, 07:08 PM   #4
Eibwen
Maybe a motion sensor aimed at the shower area to turn the fan on/off?
My wife always remembers to turn the fan on.. As she is walking out of the bathroom and the mirror is covered in fog...
Sammy is offline   Reply With Quote
Old 09-26-2007, 07:17 PM   #5
C+M Electrician
I see your point. Then put the fan on with the shower light and replace the switch with a 60 min spring wound timer.
Old 09-26-2007, 11:16 PM   #6
Rewards Points: 150
There is a switch available with a timer component. Timer is hidden behind wallplate. It turns fan on when switch is turned on, and runs the fan for the set duration after the light is switched off.
scorrpio is offline   Reply With Quote
Old 09-27-2007, 01:35 PM   #7
Rewards Points: 160
A spring wound timer is the best bet. I had to use them when my daughter's were young. But 15 minutes is more than sufficient, unless you want to run the fan for longer.
J. V. is online now   Reply With Quote
Old 09-27-2007, 02:30 PM   #8
C+M Electrician
True, although the off delay switch will cost you $50+ wereas the spring wound timer will be under 10 bucks.
Old 09-27-2007, 02:53 PM   #9
Once fried, twice shy.
elkangorito's Avatar
You could wire the exhaust fan in with the light switch so that when the light is turned on, the exhaust fan will come on also.
Of course, this idea is no good if the light is not needed (daytime).
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 01:42 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
bathroom exhaust fan wiring ventureman Electrical 1 11-29-2006 05:52 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
