Wiring A Bath Remodel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 06:24 PM   #16
Originally Posted by joed View Post
I work with the Ontario code.
It is 30-104 (a) in Ontario.
Thanks -- can you print this here out verbatum? And do you think it is common throughout the rest of Canada ..do you know whether it's also in the national plumbing rules?
Daler is offline   Reply With Quote
Old 11-21-2012, 07:17 PM   #17
Sparky
Rewards Points: 510
30-104 Protection (see Appendix B)
Luminaires, lampholders, and lighting track shall not be connected to a branch circuit protected by overcurrent
devices rated or set at more than
(a) 15 A in dwelling units;
2012 CEC
Techy is offline   Reply With Quote
Old 11-21-2012, 08:18 PM   #18
joed's Avatar
Rewards Points: 12,902
It is electrical code. I don't think there would be any reference in the plumbing code.
I only have on Ontario code book but the quote above is verbatim from the Ontario book as well.
Old 11-21-2012, 08:23 PM   #19
Thanks, Techy.
interesting ..a Florida guy would come to the rescue
What do you think is the reasoning behind the CEC rule ..why isn't doing everything on a 20A circuit ok -- as seems to be the case in much of the US?
Old 11-21-2012, 10:33 PM   #20
joed's Avatar
No limit to the number of outlets you can put on a circuit in the NEC. With a 12 outlet limit there is no need to put 20 amp circuits in most place in Canada.
As for the reason for 15 lighting circuits, maybe to protect the fixtures, which aren't fused and typically have small wires in them?
Old 11-23-2012, 06:41 PM   #21
Question
..thanks. Got another question: just now finishing off the wiring. Does the CEC allow me to add my HRV 24v Decora timer switch to the ganged bath lighting box? Can't find any reference in my handy dandy PS Knight book.
Old 11-23-2012, 07:00 PM   #22
Rochsolid's Avatar
You need a barrier between your line a low voltage. 2 gang box with a metal barrier which attaches to the ground screw as separates both wires
I know they are code compliant with tv/data cable
Rochsolid is offline   Reply With Quote
Old 11-23-2012, 11:38 PM   #23
" Euro " electrician
frenchelectrican's Avatar
You should able find the barrier to fit in your plastique box if they do have it but for metal box you should able as well.
Check that in your big box store to see if they have it otherwise my next best bet is electrical supply centre.
I am not too sure how far they updated the CEC ( Canada electrical code ) due I have older editon ( Quebec verison ) but it should be the same as Joed is posting on that.
Merci,
Marc
Old 11-24-2012, 10:04 AM   #24
Originally bought 2 plastic boxes for another project: a yellow Hubble 2-gang from HD, another gray 3-gang 3" from Ecol Electric. Neither has a slot for any sort of barrier. Can I just make my own plastic or metal plate and go from there, or does it need to be a special box with its own plate?
And on another question: the Code says no recs within 1 m of shower. Does that mean the physical shower stall itself, or just the opening part of the shower?
Old 11-24-2012, 06:56 PM   #25
joed's Avatar
It means the edge of the shower enclosure. You don't want to be able to reach them while in the shower.
Old 11-25-2012, 08:11 AM   #26
managed for find an exception subrule that states in a small bathroom the distance can be as short as 500mm minimum (BC Rule 26-710(g)).
..hmm, there are only adults in this house who don't normally go looking for trouble
Old 12-08-2012, 09:53 AM   #27
Question
Junction boxes
I have some plastic octagonal light boxes left over from my job and like to know if they can legally be used as junction boxes in my attic?
I would either nail them to the sides of a truss or directly on a truss joist (but would be covered with insulation). They would also be covered by a round plate (like the metal boxes).
Old 12-08-2012, 12:43 PM   #28
Sparky
Rewards Points: 510
as long as they have covers and are not over filled, yes you can use them
Old 12-09-2012, 08:38 AM   #29
Question
Good news, thanks. The boxes are all large and there's a set of flat covers for them.
Code requirements for remodel wiring? Mills314 Electrical 2 01-15-2012 08:25 PM
Master Bath Remodel - Need Advice meth Building & Construction 8 12-07-2010 05:31 PM
ADVICE appreciated on Bath Remodel Sunsetcliffs98 Kitchen & Bath Remodeling 9 02-01-2010 05:22 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
bath remodel jkyle Building & Construction 1 10-28-2008 05:13 PM
