Old 10-30-2010, 05:25 PM   #1
Wiring bath fan to replace ceiling light
I have a question about wiring a new bath fan. It is replacing an existing light fixture that I don't plan to replace.
Here is a picture of the existing box: I tested with a non-contact circuit tester with the power on at the breaker box.
The original light was wired to the single black wire and to the group of white wires. It looks like the same incoming electric cable that supplies the group of mixed black and white wires contains the white wire for the old light fixture--although I'm not sure as two incoming cables kind of join together to enter at the same spot on the junction box.
It's hard to see but there are three armored BX cables coming in to the box and two black, newer looking electrical cables coming in.
What do I do to supply power to the junction box for the fan? It has a pretty small housing and couldn't hold all of these wires. Do I do a pigtail? It does not look like there is room for another wire to enter the existing junction box either. However, there is play in the existing wires--room to stretch to the box on the new fan, which you can see in the left corner of the picture.
I'm assuming that this junction box is where other devices in the house are connected. I see lines heading in various directions. I'm also assuming that the source of power for the old light is in this junction box rather than in the wall switch--that makes sense to me from seeing that one of the wires in there is always hot. Is that right?
quinten is offline   Reply With Quote
Old 10-30-2010, 09:11 PM   #2
Graduate of Wiring 1-2-3
You are going to keep the light and add a fan, right? The fan was/is connected to the single wire in the picture on the left, and the group of white and black wires in the center of the picture. Correct?
If that is accurate you could connect the fan into the same wire nuts as the light. Then the light and fan will always come on together.
Lurlene is offline   Reply With Quote
Old 10-30-2010, 09:19 PM   #3
Master Electrician
Better get a voltmeter. More likely the black of the fixture was connected to the single wire on the left and the white of the fixture was connected to the gray bundle on the right.
brric is offline   Reply With Quote
Old 10-31-2010, 07:50 PM   #4
Okay I just did a "pigtail" connection. Pretty straightforward and I wanted to avoid re-wiring everything. Also you are correct about the neutral wires being where the original light was connected.
Tags
electical wiring
wiring a ceiling light that branches off to outlets What have I done Electrical 7 08-11-2009 09:24 PM
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen Travlr234 Electrical 5 06-29-2009 09:14 AM
replace ceiling fan with ceiling light pglc General Discussion 11 06-08-2009 07:12 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
