Wiring Basement Lights And I'm Lost - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 03:33 PM   #1
Wiring basement lights and I'm lost
I'm finally getting around to wiring light fixtures in our basement after the flood and what seems simple enough is making my head spin. I want 3 light fixtures, 2 on one switch and one on nother switch, on a single breaker. Does this goofy diagram make any sense? Is this the best way to go about it?
qoncept is offline   Reply With Quote
Old 02-04-2009, 04:46 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Here is a ladder diagram
(easier to understand)
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-04-2009, 05:11 PM   #3
Electrician
Rewards Points: 760
I can help you but your picture makes it more confuseing. If you could answer these few questions it would make it easier to explain.
Where are you takeing the feed to from the panel, it looks like you have marrets in the middle of nowhere.
Are the two switches together in one box or are they seperated, if they are seperated how far apart they.
How are the lights laid out to where your switches are.
darren is offline   Reply With Quote
Old 02-04-2009, 05:20 PM   #4
Keep it simple. 7 easy steps.
1. Run your 2 wire power cable into the first switch box.
2. Run a 2 wire cable from first switch box to second switch box.
This gives you your black and white, 120V power at both boxes.
3. Run a 2 wire cable from the one switch box to the single light box.
This is your switch leg
4. Run a 2 wire cable from the other switch box to the first light box and from there to the second light box.
This is your second switch leg and jumper to the second light
5. First box, wirenut all whites all together. Wirenut two blacks (power in and out) together with an 8" black pigtail (which will provide power for the switch) Remaining black switch leg goes to the second terminal of the switch.
6. Second box, tie both whites together. Two blacks go to two terminals on the switch.
7. Light boxes. Black to black, white to white.
*All bare grounds wirenut together. All metal boxes get grounded via ground screw/bare ground. All switches in plastic boxes need ground pigtails to effectivly ground the switches.
220/221 is offline   Reply With Quote
Old 02-04-2009, 08:55 PM   #5
Tool Geek
PaliBob's Avatar
I submitted "Basement Lights 1" see pic
You can also wire it up with S! as the Master and S2 controlling L3
This can also be reversed where S2 controls L1 & L2
It depends on what works best for you and whether or not the switches are in separate boxes.
Let us know how you make out.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-04-2009, 10:02 PM   #6
Electrician
Rewards Points: 760
Hey Bob do you realize your second drawing would not be ideal. They way you have it switch one will control switch 2, so if S1 is off S2 will not work.
Follow 220/221 that is the easy way i was just curious if there may of been a way to use less wire.
Old 02-05-2009, 12:43 AM   #7
Tool Geek
PaliBob's Avatar
Originally Posted by darren View Post
Hey Bob do you realize your second drawing would not be ideal. They way you have it switch one will control switch 2, so if S1 is off S2 will not work..........
It all depends on the location and the physical layout of the lights and the switches. For example if S1 is at the top of the stairs and S2 is in a Basement storage room then Basement 2 ckt would prevent luminaire L3 from accidentally being left on.
I used a similar circuit when I rewired my 1954 Mstr Bath 20 years ago. The original ceiling light was turned on with a single gang toggle that was jammed between the door jamb and the shower door. There was no room to put in a bigger box.
I used the existing box at the door for a switch to control a new set of four ceiling lights and also to power up a new box at the sink that has a dimmer for the new Alinea mirror lighting and for the fan switch. This way the mirror lighting and the Fan are always turned off when leaving the bathroom by turning off the ceiling lights.
The Alinea mirror lighting really needs a dimmer and I don't want to accidentally keep them on. They look nice but are expensive to replace. There are two 20 inchers on each side and two 20 inchers on top of the mirror with a stubby 12 incher in the center.
http://www.aamsco.com/OLD_SITE_2007/...res_Alinea.htm
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-05-2009, 12:46 AM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Use this with 220's description. I didn't show the grounds.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 09-17-2009, 03:23 PM   #9
I thought I'd already thanked you all for the input, but I guess not. I did finally get it all worked out. Wired everything up, crossed my fingers and it worked the first time. Thanks!
Old 09-17-2009, 03:49 PM   #10
Household Handyman
Rewards Points: 1,408
Bob, with all due respect to you wisdom and help on this forum, I will have to agree with "darren" on this one. It appears that you are feeding S2 through S1. IF S1 is OFF then S2 will not have electricity to work anything. UNLESS, you would be using three-way switches, then I can see this working. I'm betting this is what you were meaning to us. Thanks, David
Old 09-17-2009, 04:50 PM   #11
Tool Geek
PaliBob's Avatar
David, I explained my reasoning in post#7
Disclaimer
& Stay Safe
.....Bob Lavery
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 01:39 PM
