Wiring Basement Lighting - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 07:27 PM   #16
no
not realy we dont do that in indianapolis and i do residential
javier is offline   Reply With Quote
Old 07-25-2009, 07:33 PM   #17
New Home Owner
So even though it's in a basement, the lighting can be on standard breakers? Convience outlets should be on GFIC's because of the cement floors? I will be installing a floor, but it will be awhile before I can afford that piece.
DandHJohn is offline   Reply With Quote
Old 07-25-2009, 07:38 PM   #18
basement
you could if you want but when we do a finished basement the only thing we gfci is the bathroom outlet
Old 07-25-2009, 08:25 PM   #19
New Home Owner
I've already done that. Thank you for your help.
Old 07-26-2009, 09:57 PM   #20
gcfi in basement bathroom
Is it possible to tie in to an existing gcfi circuit when adding the new basement bathroom gcfi? The new gcfi has to be on it's own circuit but can't I share with other gcfi outlets?.... I should be able to tie in to the existing gcfi circuit so I don't have to add 1 breaker for 1 new gcfi outlet. How can I tell if that particular circuit is maxed out? One breaker is labeled as Bath GFI. The kitchen and outdoor GFIs are on other circuits. So with 3 bathrooms upstairs, adding a forth gcfi should be OK. But can it be done?
8roty is offline   Reply With Quote
Old 07-26-2009, 10:15 PM   #21
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
A bath has to have a 20 amp circuit, that shares all bathrooms, or everything in a single bathroom.
Old 07-26-2009, 10:33 PM   #22
Yes, I am familiar with that requirement. Above the breaker box where the wire comes in for the existing Bath GFI 20 amp breaker/ circuit, can I cut this wire and legally join/ make a new connection and branch to the new run of 12-2 wire to add the basement bath GFI?
***EDIT***
> I started a new thread on this question since the topic doesn't match the question anymore*** thanks
Wiring for half bath in basement ELurie Electrical 5 08-06-2011 09:06 PM
Wiring a basement Jeffrey262 Electrical 7 06-30-2009 03:59 PM
basement wiring plans for lights JonnyG Electrical 10 04-05-2009 05:46 PM
Basement wiring hotrod Electrical 17 07-14-2006 07:01 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
