Wiring A Basement Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2009, 07:46 PM   #1
Smile
wiring a basement bathroom
Hey, I'm wire in a basement bathroom I have a 4 gang box with 4 switches
1 is for overhead lights
2 is for vanity
3 is for fan
4 is for shower light
A diagram would be great but any help would be appreciated Thanks.
tdhollywood is offline   Reply With Quote
Old 04-21-2009, 08:00 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 534
Run the incoming power into the box, pigtaill the black and attach to the bottom of each switch.
Wire nut all the white wires together.
Connect the black from each device to the top of each switch.
jbfan is online now   Reply With Quote
Old 04-21-2009, 08:01 PM   #3
Rewards Points: 150
Send a message via AIM to Bocolo
Is this a riddle?? Where is the power? 12/2 or 12/3? Or more likely 14/2 or 14/3?
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 04-21-2009, 08:04 PM   #4
Do you have specific questions?
Old 04-22-2009, 12:15 PM   #5
basement bathroom
Sorry I have a basement renovation. I'm starting with the bathroom My question is how do I run these 4 switches. I have a power source coming in to the bathroom and how do I wire these 4 fixtures. Thanks
Old 04-22-2009, 12:35 PM   #6
1. Run a 2 wire cable, sized the same as your source, to your switch box .
2. Run four 2 wire cables from switch box to the four fixtures.
3. In the sw box, connect all grounds, leaving 4 pigtails if the box is plastic. If metal box, attach one ground, midway, to ground screw and connect all grounds.
4.Connect all white wires.
5. Install 4 pigtails on to the black power wire.
You now have 4 hot pigtails to feed the switches and 4 switch legs going to each fixture. If you can't figure out the rest, call someone
220/221 is offline   Reply With Quote
Old 04-22-2009, 04:35 PM   #7
basement bathroom
Thanks for the help!! A diagram would be very helpful
Old 04-22-2009, 05:10 PM   #8
Want me to twist the wirenuts on for you?
You have one cable bringing in power to the switch box and four cables taking power to the individual lights and fan.
You tie the bare wires together, you tie the whites together and you put 4 pigtails (6 to 8 inch pieces of black wire) on the hot.
It's five simple steps. Do them one at a time and you won't get confused.
Here's a tip. Run the power in cable into the left hand top of the sw box and run the switch leg cables into the box in th eopening directly above where you want the swithes to be. Your "make up" will be cleaner.
And don't cut your cables too short. Homeowners ALWAYS do this. Leave 12" to work with and cut the wires to size as necessary.
Completing a roughed in basement bathroom Bob in St. Louis Plumbing 8 11-18-2011 12:12 PM
Wiring for half bath in basement ELurie Electrical 5 08-06-2011 09:06 PM
Venting basement bathroom fixtures ccathy247 Plumbing 1 11-01-2008 03:44 PM
Basement finishing : Bathroom and Wetbar Outlets cderner Electrical 8 07-25-2008 06:27 PM
Safest and most efficient way to run wiring in a basement? drh Electrical 6 01-07-2008 09:04 AM
