Wiring A Basement Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2008, 02:58 AM   #1
Wiring a basement bathroom
Can I put a bathroom Gfci receptacle at the end of a bedroom receptacles 20 amp ckt. and it be code? Also can i put the bath fan/light on a bedroom light 20 amp ckt. and it be legal? FYI these are 2 separate ckts.
While I'm at it, can i put a Kitchen Gfci at the end of a bedroom 20 amp receptacle ckt.?
Thanks guys/gals.
luweee is offline   Reply With Quote
Old 12-21-2008, 03:28 AM   #2
DIYer
Bathrooms are supposed to be dedicated. Hair dryers/curlers/etc are high draw.
Gigs is offline   Reply With Quote
Old 12-21-2008, 04:51 AM   #3
Code says that they must be dedicated, The fan and light in the bathroom CAN run off of the bath ckt.
rgsgww is offline   Reply With Quote
Old 12-21-2008, 12:57 PM   #4
Rewards Points: 2,350
Just to clarify, the bathroom receptacle legally needs to be on its own circuit. The lights can be on the bedroom lighting circuit however. You could put the kitchen receptacle on the bedroom circuit, as long as the receptacle doesn't serve the kitchen countertop. Countertop receptacles need to be dedicated, and there must be at least two circuits.
Old 12-21-2008, 08:50 PM   #5
Hey InPhase 227
I called it a kitchen.... it's actually a bar in the basement. Do I need 2 separate ckts.?
Also, the bathroom? okay the lights can be on the bedroom ckt. how bout the fan? same same??
If I post my drawing can someone take a look to see if my wiring is suffice for code (in there oppinion)?
Old 12-22-2008, 11:00 AM   #6
joed's Avatar
Rewards Points: 11,992
Does it have a sink? A kitchen is defined a area with a sink and permanent facilities for food preparation and cooking.
Old 12-22-2008, 11:34 AM   #7
Registered User
Termite's Avatar
With a sink only it is a bar. With food prep appliances it becomes a kitchen, and two circuits for countertop receptacles are requried, GFCI protected, and spaced according to code. If only a bar, no receptacle spacing requirements apply, but any receptacle within 6' of the sink must be GFCI protected.
As for the bathroom, the GFCI receptacle does not have to be on a dedicated circuit if that bathroom is the only part of the home the circuit serves. The lights, fan, and GFCI receptacle can be combined on the same circuit, but that circuit can only feed that bathroom. Reference section E3603.4(exception) of the International Residential Code, 210.11(c)(3) of the NEC.
Old 12-22-2008, 11:53 AM   #8
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
What are food prep appliances? Does this just mean a regular range? Would a "bar area" with a pizza oven, fridge, and microwave be considered a kitchen?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 12-22-2008, 12:02 PM   #9
DIYer
Jamie
If you have that much crap, you'd want to follow the code for a kitchen anyway, even if it's not required.
Old 12-22-2008, 02:55 PM   #10
Registered User
Termite's Avatar
Jamie
Yes, a pizza oven or a microwave is a cooking appliance, if the area is to be used for the preparation of food the code considers it a kitchen. The code isn't specific as to what food prep appliances are, but stoves, cooktops, ovens, warmers, and microwaves would top the list for most inspectors. A fridge is common in bar areas and wouldn't trigger me to consider it a kitchen, nor would a dishwasher, insinkerator, or trash compactor.
Old 12-22-2008, 03:27 PM   #11
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Is this receptacle "THE" bathroom receptacle or an additional receptacle in the bathroom? If it is simply an additional receptacle, the answer is yes.
Yes.
Is this receptacle in addition to the required small appliance circuits? If so, the answer is yes.
John
jrclen is offline   Reply With Quote
Wiring Problem in Bathroom notasparky Electrical 7 10-27-2008 07:34 PM
rewiring a basement bathroom - check my wiring please mslide Electrical 2 07-10-2008 07:06 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
