Wiring Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 07:28 AM   #1
Post
wiring basement
Hello Everyone.
I am going wire my rec room, office, washroom and bedroom in the basement. I like to add 7 receptacle in rec-room and office for music and home-theatre. 16 pot lights. receptacle in washroom and bedroom, light in washroom and closet.
I am using 14.2 guage wire and thinking to make following circuits
Circuit 1; include all 7 receptalce in rec-room.
Circuit 2; include 6 pot ligjts in rec-room.
Circuit 3; Include 6 pot lights in office.
Circuuit4;include receptacle and light in washroom, bedroom, light in closet.
Thinking to add 3 more breakers in my panel. I hope i am doing right.
Any suggestion and alternation in plan is welcome and highly appreciated.
Sorry for lengthy question. Wiring is headshaking for me.
Thank-you Ranjodh
raulakh is offline   Reply With Quote
Old 09-30-2009, 07:44 AM   #2
Lights can all be on one circuit, 2 switches
Laundry needs a dedicated 20a circuit - no lights
Rec room you might want 2 circuits if you will have a theatre system, computers etc in there
I only run 12g 20a circuits for outlets, vacuums take a lot of power these days
As does a space heater, dehumidifier if one is ever needed
Old 09-30-2009, 08:07 AM   #3
look into your local codes also. in my area i need afci (arc fault) breakers for any room besides kitchen and bath and garage. As i am doing my basement i did each room as a circuit. that way if one blows you dont loose power in the others.
baum is offline   Reply With Quote
Old 09-30-2009, 09:28 AM   #4
Rewards Points: 1,418
Give the bathroom its own 20 amp. circuit with GFCI.
Also any circuit that has receptacles in an unfinished area (bare walls or floor) in the basement needs GFCI protection.
Old 09-30-2009, 10:13 AM   #5
Rewards Points: 150
Correct me if I am wrong, you may use a single outlet, if it is a dedicated use (i.e. sump pump).
Single outlet that is, not a duplex.
[IMG]file:///C:/DOCUME%7E1/xtxp007/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
TJ_in_IL is offline   Reply With Quote
Old 09-30-2009, 10:37 AM   #6
Licensed Pro
Depends on what code cycle your area is following... that exception was removed in the 2008 NEC.
Old 09-30-2009, 08:42 PM   #7
Electrician
Rewards Points: 760
Also depends on the location of the OP. To all users if your new to the form please put your location in your profile, rules in Canada and the USA are different.
darren is offline   Reply With Quote
Old 09-30-2009, 08:46 PM   #8
Yeah....his IP traces back to Canada
Old 10-01-2009, 11:26 AM   #9
Joe F's Avatar
Rewards Points: 294
I was always told to mix receptacles and lighting so as not to wind up with some "heavy load" and "light load" circuits. Also, in a basement with no natural light, if a fixture pops a breaker you don't lose all of the lights.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 10-01-2009, 12:34 PM   #10
Unfortunately I didn't think about mixing the loads on the circuits when I did my basement. Instead I did something like circuit #1 goes into this wall and serves the receptacles in the rooms on both sides (also feeds the switch boxes in the wall), circuit #2 goes into that wall and serves the receptacles in the rooms on both sides, etc.
Old 10-02-2009, 06:44 AM   #11
wiring
Thank-you very much. I am all set
Basement Wiring Questions whirly Electrical 8 03-30-2009 01:52 PM
Wiring for new basement, design help jthawkins Electrical 20 03-06-2009 02:23 PM
Advice on basement shop wiring WoodworkerDave Electrical 4 04-05-2008 01:12 PM
Basement wiring Fred Electrical 1 12-30-2003 11:53 PM
