Wiring In Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 06:32 PM   #1
Wiring in Basement
Hi,
I am doing a run of outlets, and I am looking to do the rough run prior to my inspection. Everything is wired except for the home runs to the breaker box. I am wondering if I am able to run the wire under the joists, stapled to the board running along the foundation as in this picture. It's about ten feet and this part of the basement will remain unfinished, and I don't want to put any unnecessary bore holes through the joists.
Thanks!
brm6685 is offline   Reply With Quote
Old 07-09-2012, 06:43 PM   #2
Yikes ! No pressure treated sill plate. I wouldn't staple anything to it cuz your eventually gonna have to replace that when it rots. As far as your electrical question I'm sure a qualified electrician will answer that one for ya . Good luck !
CopperClad is offline   Reply With Quote
Old 07-09-2012, 07:45 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Yes, you can staple to the plate. Just so you know, it can be a pain in the ass at times though... if you have a lot of wires I would use stack its and just screw them to the plate.
Old 07-09-2012, 07:48 PM   #4
E2 Electrician
Originally Posted by CopperClad View Post
Yikes ! No pressure treated sill plate.!
It's not always an issue.... Of course, I wouldn't build with out it.
multiple light switches on existing basement Wiring fdasilva Electrical 8 05-31-2011 09:30 AM
Basement Electrical Wiring Question psqually Electrical 11 05-15-2011 04:18 PM
Advice needed for Basement Wiring hazey313 Electrical 6 10-04-2010 11:02 PM
Basement Wiring Questions whirly Electrical 8 03-30-2009 12:52 PM
Wiring for new basement, design help jthawkins Electrical 20 03-06-2009 01:23 PM
