Old 10-05-2010, 10:21 PM   #1
Wiring for barn
I have a barn that has 14 gage wire into it. I only have a few plugs and a fan. I would like to put a circuit breaker box in the barn, if I change to eight or 10 gauge wire in the future would I have to change the circuit breaker panel box? Inthe future i may be using heavier tools, therefore needing heavier gauge. My barn is 115 feet from my house
fjacky is offline   Reply With Quote
Old 10-05-2010, 11:02 PM   #2
Xtreme DIY'r
Wiring for barn
With 14g wire @115' you have a voltage drop of 10.5v = 8.8% which is on the high side
That's IF you pull the full 16a
With 10g wire @115' you would have a voltage drop of 4.2v = 3.5% which is still a little above recommendation
If you are going to run new wire you might want to run a small sub or MWBC to have 2 circuits
How much power do you need ?
What do you have for a circuit breaker panel in the barn ?
I used #6 wire for a 60a sub at about the same distance
Old 10-05-2010, 11:19 PM   #3
Wiring for barn
At this time i only plan on a few plugs, 2 lights and a fan. When i had my small shed i just had one plug that ran of the wire. Maybe i can just run a fan off of that. Just wanted some sort of panel back there just in case i draw too much power
Old 10-05-2010, 11:24 PM   #4
Xtreme DIY'r
Wiring for barn
Usually a panel is only used with a larger feed
If this is running off a 15a breaker or fuse in the house then that will trip if you draw too much power
With #14 wire it should not be on a 20a breaker
If you put a breaker box in the barn & a 15a breaker its possible the house breaker will still trip 1st
Old 10-06-2010, 07:10 AM   #5
dSilanskas's Avatar
Wiring for barn
If I was you I would install a 100 amp sub panel for future. Just in case down the road you have larger equipment or want to finish off part of the barn the option will be there
dSilanskas is offline   Reply With Quote
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 33 03-18-2009 08:11 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
